Under bonnet sherlock required!
- Tryeverythingonce
- Novice MGer
Under bonnet sherlock required! was created by Tryeverythingonce
Posted 4 years 10 months ago #196899Please Log in or Create an account to join the conversation.
- sworkscooper
Replied by sworkscooper on topic Under bonnet sherlock required!
Posted 4 years 10 months ago #196901John .
- Tryeverythingonce
- Novice MGer
Replied by Tryeverythingonce on topic Under bonnet sherlock required!
Posted 4 years 10 months ago #196902Please Log in or Create an account to join the conversation.
Replied by talkingcars on topic Under bonnet sherlock required!
Posted 4 years 10 months ago #196942Left hand drive models have the reverse with the servo on the left as you look at it.
Posted 4 years 10 months ago #196943
- Tryeverythingonce
- Novice MGer
Posted 4 years 10 months ago #196944Please Log in or Create an account to join the conversation.
- neilpinleeds
Replied by neilpinleeds on topic Under bonnet sherlock required!
Posted 4 years 10 months ago #196946Good to know...maybe the engineers disappeared down a cul de sac with that one. Don't have enough experience to know if it's a common solution.
It does seem odd. I'd assumed that it was the usual bodge for RHD cars only with LHD pedals feeding direct to the servo.....
Interestingly, the MGF Cup race cars had the brake servo mounted directly above the brake pedals and deleted the need for the cross bar. So it could be done and if used in racing I expect an improvement.
No idea why both LH and RH models should both have it. It looks so much likes a LH/RH conversion. Makes no sense to a simpleton like me since it could be mounted above. A company called Tech-Speed picked MGF off production line and converted them into Cup Race Cars, including remounting the servo into the "correct" place.
Cheers.
