Should I be worried (again)?
  • Hogweed
Should I be worried (again)? was created by Hogweed
Posted 2 months 3 days ago #223351
So I had an HGF scare last year some time, which turned out to be a false alarm, due more to my inherent paranoia than anything else
New stainless pipes, and been absolutely fine since. However, I decided to check my coolant level a week or two ago, and saw this bit of mayo around the cap.
Coolant level fine, no mayo in the oil, engine temp fine... somebody said this is likely just a bit of condensation - what do you think?
Thanks as ever
by Hogweed
Replied by D4KGP on topic Should I be worried (again)?
Posted 2 months 3 days ago #223352
Hi clean the cap and wipe around just inside the tank, then use the car regularly and see what happens. Condensation happens when the cars are not used often, I have been led to believe.
Replied by Delbourt on topic Should I be worried (again)?
Posted 2 months 3 days ago #223354
Mine went under a cover in mid to late November last year. It wintered under that cover until MOT time and it was MOT tested in late March.
Grief we had a lot of rain over winter. Some condensation appeared in the oil temp gauge and I did blow hot air around the cab a couple of times to keep condensation at bay.
I had no such trouble in the expansion tank.
Perhaps not what you wanted to hear. But that is the truth.
Replied by TA22GT on topic Should I be worried (again)?
Posted 2 months 3 days ago #223355
Was new antifreeze put in when the underfloor pipes were changed or was the old antifreeze used?
I ask because it looks a bit grotty.
You can check it with a multimeter to see if it is still functioning.
  • Hogweed
Replied by Hogweed on topic Should I be worried (again)?
Posted 2 months 3 days ago #223357
Yes new coolant - I was told - but the inside of the header tank was all filthy from the old corroded pipes (that's one of the reasons I previously thought my gasket had gone), so I think it's just the inside of the tank. But that's given me an idea - I'll suck some of the fluid out with a syringe tomorrow and see what it looks like! Will report back...
Sorry, what should I check with the meter?
by Hogweed
Posted 2 months 3 days ago #223358
If it's new antifreeze you will be fine.
If you have a digital MM or a Fluke you can get an idea if it is still good.
Set it to Voltage, connect to a good earth and stick the positive probe in the header tank.
You are looking for tenths of a volt.
Ov to .2v is good.... .3v is starting to go off.. .4v change it.
Yours will be fine.
The following user(s) said Thank You: Hogweed, Red110
Posted 2 months 2 days ago #223362
On a totally different project I acquired a replacement header tank that was significantly discoloured and slimy inside.
I cleaned it out by putting a small quantity of a coarse sand containing some sand used for mortar. With some water in the tank too I swirled it around until the whole thing became clean. Worked a treat and reached parts that I could not reach otherwise.
The following user(s) said Thank You: Hogweed, Red110, TA22GT
Posted 2 months 2 days ago #223363
Thanks for that.
I removed mine to clean it when I replaced the antifreeze but couldnt get it spotless.
Tried all sorts of chemicals.
Posted 2 months 2 days ago #223367
Dishwasher tabs are good for that, but you need patience also.
Posted 2 months 2 days ago #223368
How do you know I don't have much patience?!
  • Hogweed
Posted 2 months 2 days ago #223369
OK... stuck the meter in it, and it started off around 80mV, and gradually dropping. I got tired of watching it when it got to maybe 65mV, but still falling.
Despite having a brain the size of a planet (little age giveaway there), I've never been able to count, but I think that's less than 0.1V...?
Collant looks good I think? The glar's on the outside of the syringe.
by Hogweed
Replied by argentas on topic Should I be worried (again)?
Posted 2 months 2 days ago #223370
Speaking from experience, a pastry brush was very effective at cleaning the ibits you can reach through the filler hole, but next time I would probably avoid carrying out this task whilst the wife was home...
2004 MG TF 135 Sunstorm (CBT Nightfire 3)
Time to create page: 0.460 seconds
