Doors Not Unlocking - '05 TF 115
Doors Not Unlocking - '05 TF 115 was created by Witho12
Posted 1 week 2 days ago #224339
Hi everyone!
I have recently took ownership of a quite neglected 2005 tf 115 in the beautiful ignition blue.
Cars been sat dead for a while, replaced battery with a charged one, indicators flash when unlocked and locked, and the Immobiliser turns off, foot well lights turn on and off, but the doors do not unlock, every so often you can here a squeel/click from the solenoid but doesn't unlock. We've done the welding wire trick to pull the locks up from inside and still to no avail.
Is there anything else I could do before in un-velcroing the rear window and cave man into it?
I have a suspicion that the pektron unit is knackered :/
Thanks,
Adam.
Last Edit:1 week 2 days ago by Witho12
Last edit: 1 week 2 days ago by Witho12. Reason: Spelling and format
Replied by Roverlike on topic Doors Not Unlocking - '05 TF 115
Posted 1 week 2 days ago #224340
If I am not mistaken TF 115 does not have central locking. You need to open the door by the key.
Replied by Cobber on topic Doors Not Unlocking - '05 TF 115
Posted 1 week 2 days ago #224345
Yeah I seem to recall the TF115 was the poverty pack specification, and amongst various goodies that it was denied, was central locking.
Does it have lock barrels in both doors?....or is it only the drivers door that has a lock barrel? .............If it's only the drivers door that has a lock barrel, then it has central locking.
Replied by exengineer on topic Doors Not Unlocking - '05 TF 115
Posted 1 week 2 days ago #224351
sorry cannot help but i have an 05 TF 115 from new with central locking. think they chucked parts bin at last few to be made
Last Edit:1 week 2 days ago by exengineer
Last edit: 1 week 2 days ago by exengineer.
Replied by Witho12 on topic Doors Not Unlocking - '05 TF 115
Posted 1 week 2 days ago #224352
Door lock is only on the drivers side, and it has fallen into the door, yes, typical.
She's a bit of a weird spec, has glass rear window, power windows, power mirrors, central locking.
I've done the leave dead put full battery on and click unlock a bunch of times, Immobiliser turns off interior light comes on but nada on the deadlock.
Cheers,
Adam.
by Witho12
Replied by Notanumber on topic Doors Not Unlocking - '05 TF 115
Posted 1 week 2 days ago #224353
Not all of them, My 2002 115 came with central locking. The differences between that car and a 135's standard equipment were manual mirrors, no rear speakers or tweeters (which I added) .
The 115 version of most of the special editions seemed to have 135 level equipment as standard. Mine was just entry level though so Im assuming central locking will have been an optional extra.
Posted 1 week 2 days ago #224354
Are you saying the deadlock is jammed on and if so is it one door or both doors ?
Posted 1 week 2 days ago #224355
Both doors mate. It made a squeal and a faint click. Then used a different battery and it click like it was trying to do something. But both handles are loose. The door lock stubs next to the window (sorry forgot the proper name) were down, and used welding wire to pull BOTH up but it did nothing.
by Witho12
Replied by sworkscooper on topic Doors Not Unlocking - '05 TF 115
Posted 1 week 2 days ago #224358
Hi. I recently tried to help out mate with a similar problem, however in his case the hood was open so we could turn the ignition on. All cars with central locking  have a safety feature where  in the event of an accident the Inertia switch will cut off fuel and  'Pop' the locks. Can you turn on the ignition and give the inertia switch a sharp tap on the body of the switch?  It worked for me  in this particular case.
John .
Last Edit:1 week 2 days ago by sworkscooper
Last edit: 1 week 2 days ago by sworkscooper.
Posted 1 week 2 days ago #224360
Hi there,
Yeah in my case she's closed, and once I've un latched the glass and climbed through to unlatch the hood I'll give that a try, but I have a gut feeling the pektron relays have give up the gun. Where abouts is this inertia switch?
Cheers,
Adam.
by Witho12
Posted 1 week 2 days ago #224362
If you open the boot and look under the  left hand side of the engine bay grille , its a small black  square shaped switch  with a multiplug at its base and a rubber cap on top near the fuel filter. As I say the ignition was on in my case but when I gave it a sharp tap , both locks opened.
Posted 1 week 2 days ago #224363
Oh brilliant thank you, I'll see how that goes this weekend. In Scotland all week from Staffordshire :<
by Witho12
Time to create page: 0.404 seconds
