TF window inoperable
TF window inoperable was created by Bob Williams
Posted 2 days 8 hours ago #224524
TF160 2004. Passenger window not working. Checked fuse, F5, in passenger compartment, and switch (by swapping with driver side). Removed door card and connected 12v supply direct to red wires going to motor. Worked perfectly up and down. Reconnected to switch, nothing. What am I missing? Any suggestions please.
Last Edit:2 days 8 hours ago by Bob Williams
Last edit: 2 days 8 hours ago by Bob Williams.
Replied by Notanumber on topic TF window inoperable
Posted 2 days 7 hours ago #224525
Hi Bob, its worth reading this thread where i had the same problem 2 years ago. The search feature is quite useful as these cars have been around for quite a while.
Fuse F5 is not the only relevant fuse. I was advised to also check Fuse 9 which was indeed blown. The usual cause of that fuse going is a fault with the engine bay fan hence the fuse only blows when the rear  fan is enabled by a high level of engine bay heat. . Tbar thread on passenger window fail
Time to create page: 0.475 seconds
