So then.............What next??
So then.............What next?? was created by slippy
Posted 14 years 9 months ago #10219
Im in no rush at all but whats the best way to get more power / performance from my VVC?
Ive got the Viper enclosed induction kit fed from the n/s vent with scoops.
Ive got a 52mm Throttle body
Ive got a stainless exhaust.
Whats the difference between mine & a 160??
Whats mems 3?? I assume mine being a 1997 its not mems3
Oh & before you start Clive.........I cant afford to supercharge!! :dc:
Stu
by slippy
Replied by David Aiketgate on topic So then.............What next??
Posted 14 years 9 months ago #10224
Remap?:dunno:
  • bacchus
Replied by bacchus on topic So then.............What next??
Posted 14 years 9 months ago #10228
David Aiketgate;10224 wrote: Remap?:dunno:
As I understand it, being a 97 its not mems 3 so a remap isn't possible, but how about a ported and flowed Trophy 160 head and a cam upgrade? it seems to work for AndrewR
Also have a look here, it might give you a few ideas;
http://kengine.dvapower.com/
Personally I want this, but I can't afford it....lol
http://www.s262612653.websitehome.co.uk/#vvc190kit
Craig
by bacchus
Replied by andrewr on topic So then.............What next??
Posted 14 years 9 months ago #10229
Basicly mine is a Ko6A. As you canot remap MEMS 1, I have added a fuel preasure regulator and set at 4.0bar this gives me approx 175HP. My next power gain or rather the cheapest route left to me is loose 35kg!
by andrewr
Replied by gotenks1321 on topic So then.............What next??
Posted 14 years 9 months ago #10230
Being a '97 VVC means yours will be MEMS2J and unable to take a remap.
The next stage would be to go down the head porting route via Dave Andrews or someone else. There is no need to blank the VVC mech off and go for solid cams so don't listen to anyone out there who tells you that you must :shake:
Have you thought about handling mods before going for more power? Means you'll be able to drive harder and make use of the available power that you already have safely :yesnod: Lowering pins, polybushes, solid subframe mounts, TF Torsion bars etc
Replied by slippy on topic So then.............What next??
Posted 14 years 9 months ago #10248
gotenks1321;10230 wrote: Have you thought about handling mods before going for more power? Means you'll be able to drive harder and make use of the available power that you already have safely :yesnod: Lowering pins, polybushes, solid subframe mounts, TF Torsion bars etc
I know about the polybushes & lowering pins but you lost me on solid subframe mounts?
TF Torsion bars? are they the chassis braces that go underneath & in the engine bay? Are they a direct fit from a TF or is there welding involved?
Can you upgrade from MEMS2j to MEMS 3?
Thanks
Stu
by slippy
Posted 14 years 9 months ago #10251
Slippy;10248 wrote: I know about the polybushes & lowering pins but you lost me on solid subframe mounts?
Thanks
Stu
Here you go, these two links should hopefully explain it all :yesnod: Not cheap though :shake:
http://www.vehiclehandlingsolutions.com/page3.htm
http://mgf.ultimatemg.com/group2/body/index.htm
Yep, they are indeed the chassis bars and they do involve a little welding, one reason I haven't done them yet :o
You could upgrade the MEMS system but you'd need all the ignition system and possibly a bit more, I looked into it briefly but the general concensus was that it's not worth it and with the mods I'm planning I'll be going to Emerald route anyway :whistle: If you were to fit a 160 head then I imagine you could swap the ignition system over at the same time :yesnod:
Replied by cjj on topic So then.............What next??
Posted 14 years 9 months ago #10259
I think the main differences between the VVC and the TF160 are the MEMs version, the improved airbox (which you have sorted) and the valve sizes in the head.
Time to create page: 0.557 seconds
