Getting rid of my arial?
Getting rid of my arial? was created by Adam-Mgtf
Posted 14 years 9 months ago #10322
Hey guys,
As part of my project i want to clean the lines of the car up, part of that includes removing the door handles
but what i'd like to do as well is remove the arial.... not fit a smaller one but completely remove it
in my classic mini i had his god awful plastic spatchula type thing stuck to my windscreen, which looked awful but worked
anyway what im thinking is can i hide a Effective arial somewhere inside the car so that i can remove the arial mount and smooth it over?
anyway im sure you ICE guys will be able to easily answer this :D thanks
Replied by andycolm on topic Getting rid of my arial?
Posted 14 years 9 months ago #10325
Try a run of copper wire around the inside of the boot. I did this when my arial snapped and it worked fine.
Replied by cjj on topic Getting rid of my arial?
Posted 14 years 9 months ago #10327
You can put an aerial inside the car, but be prepared for poorer reception as there will be metalwork etc between the aerial and the signal source. This is why an aerial is normally mounted on the highest available part of the car.
Replied by Adam-Mgtf on topic Getting rid of my arial?
Posted 14 years 9 months ago #10334
CJJ;10327 wrote: You can put an aerial inside the car, but be prepared for poorer reception as there will be metalwork etc between the aerial and the signal source. This is why an aerial is normally mounted on the highest available part of the car.
could i fit it say where the clips are for the back of the hood? all that should stop reception would be the roofs canvas?
Posted 14 years 9 months ago #10339
Adam-MGTF;10334 wrote: all that should stop reception would be the roofs canvas?
And the metal frame. The only way to find out is try it.
On a side note, aerials are normally a tuned length for a certain frequency, or range of frequencies, so running a length of wire may be a bit hit or miss.
I would tend to go for an in-car amplified aerial.
http://cgi.ebay.co.uk/CELSUS-SCREEN-GLASS-MOUNT-AMPLIFIED-CAR-AERIAL-AN7920_W0QQitemZ200326876841QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item2ea4698ea9
Posted 14 years 9 months ago #10341
CJJ;10339 wrote: And the metal frame. The only way to find out is try it.
thats pretty much what i had in my mini... always sounded fine but it was stuck to the windscreen lol
for £7 i might just give it a try at some point, if it doesnt' work then i can have a think about something else, possibly a BMW style bee sting arial somewhere? don't really like them but still
Replied by adamelphick on topic Getting rid of my arial?
Posted 14 years 9 months ago #10342
What about the area behind the windscreen trim?
Posted 14 years 9 months ago #10343
AdamElphick;10342 wrote: What about the area behind the windscreen trim?
at the top you mean mate? where the rear view mirror is? i thought about that :)
depends how hard it would be to wire it in there... cant really be bothered removing all the dash again lol
Posted 14 years 9 months ago #10344
Adam-MGTF;10343 wrote: at the top you mean mate? where the rear view mirror is? i thought about that :)
To get the trim off all you do is unbolt the sun visors and pull it off.. it is just held on with clips. Theres a bit of space behind it and the windscreen surround itself I think is hollow and if I remember rightly has holes to access the cavity behind the trim!
Posted 14 years 9 months ago #10346
AdamElphick;10344 wrote: To get the trim off all you do is unbolt the sun visors and pull it off.. it is just held on with clips. Theres a bit of space behind it and the windscreen surround itself I think is hollow and if I remember rightly has holes to access the cavity behind the trim!
i have no sun-visors so should be simples lol...
its getting the wire from the head unit to the cavity that may be tricky
Posted 14 years 9 months ago #10348
Adam-MGTF;10346 wrote: i have no sun-visors so should be simples lol...
Might be able to get up into the void with some coat hanger wire maybe from under the steering wheel area.
Posted 14 years 9 months ago #10349
AdamElphick;10348 wrote: Might be able to get up into the void with some coat hanger wire maybe from under the steering wheel area.
hmm not a bad idea... watch this space lol
Time to create page: 0.528 seconds
