Squeak from passenger front side of car
any ideas as to the squeak, i have lubed every rubber point with silicon spray, grease gunned all 4 suspension nipples until it oozed out.
wheels off no squeak, wheels on and left or hand lock squeak...also the pushing up and down its squeaks:dunno:....i am going squeaking mad the noise is noticable:frown:
Any practicle suggestions more than welcome.......could it be the track rod ens but on inspection the rubber is all in tack and not split as for the rubbers all look ok:dunno:, steering rack is positive with full movement......
confused and all squeaked out
Replied by David Aiketgate on topic Squeak from passenger front side of car
Posted 14 years 9 months ago #10555wilddog;10512 wrote: Hi,
It's not the tyre rubbing on the plastic arch liner is it?:dunno:
Replied by wilddog on topic Squeak from passenger front side of car
Posted 14 years 9 months ago #10574Please Log in or Create an account to join the conversation.
- adamelphick
Replied by adamelphick on topic Squeak from passenger front side of car
Posted 14 years 9 months ago #10575wilddog;10574 wrote: No m8ty but all this info helps and reminds me areas I have checked and crossed off the list, all gassed up suspension and no rub marks either top or inside wheel arch, nor does the wheel touch anything inside......its a a bit irritating as the noise does sound a bit, now if it was to break it would solve the squeak it does not alter when transporting a passenger, it sounds when bounced and sounds when turned, could it be the suspension strut? as it has rubbers top and bottom, could the ones underneath have perished? or moved? just a very wild guess............
First thing to eliminate are the needle roller bearings in the lower suspension arm... these are the same as the Metro and get damp, loose their grease and then begin to break down... a good squirt with a grease gun until clean grease oozes from the edges of the rubbers will sort that.
Then if it's not that it could be the lower suspension arm rear bush - mine has got some grit between it and the body and squeaks when going over bumps - when it's warmer I'll pop it off and clean it out.
As it is localised on one side it's unlikely to be roll-bar bushes.
Does it sound 'metallic squeak' or 'rubbery squeak'?
Posted 14 years 9 months ago #10579I have on order a pair of front lower rubber bushes for the suspension leg where it bolts onto the upper arm.
Replied by mgfmad on topic Squeak from passenger front side of car
Posted 14 years 9 months ago #10597Also - is your wheel bearing OK?
MG TF LE500 27 of 500
Posted 14 years 9 months ago #10603regards
Posted 14 years 9 months ago #10860One nightmare was the passenger side top absorber nut had been fastened all the way down? and would not release and had to split the nut/dremel with cutting discs, good laugh that was...anyway this may be my solution to this issue but the old shocks not working came as a shocker
Thanks for all the advice folks much appreciated
Posted 14 years 9 months ago #10874wilddog;10860 wrote: Well some good news, gagged the wife and its so quiet in the car now....no seriously, I checked each shock absorber and found the passenger side could be compressed with just my fingers? the drivers side was ok......new gas adjustable shocks from Sussex classics and now no noise, no squeak or creek..........fitted these today in the rain.
Good to hear you've got to the bottom of the squeak, anyway.:yesnod:
You should have named this post:-
OLD SHOCKER SHOCKER :lollol:
Posted 14 years 9 months ago #10889LOL its good to laugh, many thanks
