There are some things you cannot forgive MG for.
There are some things you cannot forgive MG for. was created by cjj
Posted 14 years 9 months ago #10941
Been fiddling today between the snow showers.
I took the snorkel off the top of the blower so that I could seal it properly and get rid of one of my leaks.
I couldn't believe that the 3 bolts on the front edge didn't have captive nuts, considering that it is nigh on impossible to get a spanner on them. It must have been installed before the master cylinder. What were they thinking. :dunno:
I ended up jamming a screwdriver in to my nuts to hold them in place. ;)
So, another mod I did was to use my rivnut tool and fit some rivnuts so I wouldn't have the same problem next time.
Once it was off I dried the seal off and applied some roofing sealant to the bulkhead. Non of your namby pamby silicone sealant, but some house roofing/guttering type stuff. :)
Put the snorkel back on and bolted it back into place.
Smoothed the sealant off around the edge and hopefully I can forget about the leak.
Put my carpet, passenger seat and door cards back in. So I nearly have a complete car now. :yesnod:
Replied by stamford on topic There are some things you cannot forgive MG for.
Posted 14 years 9 months ago #10944
I'm sure I'll find this out soon enough. Good work!
The only part I have come across so far is the crap design of getting the sound proofing carpet/mould from out of the engine cover/rear roof area.
2000 MGF 1.8i SE Wedgewood
2002 MG ZS200 Trophy Blue
1999 Land Rover Discovery series 2 TD5
Replied by David Aiketgate on topic There are some things you cannot forgive MG for.
Posted 14 years 9 months ago #10945
Could you show what a 'rivnut' is/does.:dunno: I'm intrigued.
Oh and thanks for the quote:whistle:
Replied by mgfmad on topic There are some things you cannot forgive MG for.
Posted 14 years 9 months ago #10947
Nice work CJJ - as you say, why were captive nuts not used:cuckoo:
MG TF LE500 27 of 500
by mgfmad
Replied by cjj on topic There are some things you cannot forgive MG for.
Posted 14 years 9 months ago #10950
David Aiketgate;10945 wrote: Could you show what a 'rivnut' is/does.:dunno: I'm intrigued.
Here you go mate.
http://en.wikipedia.org/wiki/Rivet_nut
http://www.cardinalcomponents.com/fasteners.htm
You use it like a big rivet. You drill a hole, screw the rivnut onto the end of the tool, place it in the hole and squeeze the handles. This causes the rivnut to expand in the hole and grip to the metalwork. You now have a captive nut. Very useful tool.
Replied by the jester on topic There are some things you cannot forgive MG for.
Posted 14 years 9 months ago #10951
well you learn something new everyday....id never heard of these rivnuts before...ingenious little thing
[SIGPIC][/SIGPIC]Is so skint he's off to become a sperm donor.....when i think of the money i've let slip through my fingers!!!:whistle:
Replied by adamelphick on topic There are some things you cannot forgive MG for.
Posted 14 years 9 months ago #10952
Where you get your rivnut tool Clive? That link only has a more manual version with allen keys!
Posted 14 years 9 months ago #10953
I think I got mine off ebay
Replied by swerving on topic There are some things you cannot forgive MG for.
Posted 14 years 9 months ago #10954
Ingenious solution Clive.... I used 6mm nuts ttached to a long flat bladed screwdriver with insulation tape then a bit of fiddling got them threaded on.
Respect though!
Older but certainly not wiser!
Posted 14 years 9 months ago #10956
Swerving;10954 wrote: Ingenious solution Clive.... I used 6mm nuts ttached to a long flat bladed screwdriver with insulation tape then a bit of fiddling got them threaded on.
Respect though!
I probably would have done similar if I didn't already have the rivnuts.
Time to create page: 0.787 seconds
