Inlet Manifold Gasket on a 135?
  • Visitor
  • Visitor
Inlet Manifold Gasket on a 135? was created by a Guest
Posted 14 years 9 months ago #11053
Hello all (first post, wooo).
Ive been having problems locating a water leak now for a while.
The car has lost 10 litres of coolant in around 3-4weeks.
Recently she's become difficult to start and very very steamy for the first few mins (im talking total white out).
She still runs ok though.
I've now taken the decision to take her off the road for now until it can be sorted.
Sadly she has overheated 3 times as a result of coolant loss (i think) accompnied by a large colud of steam. my Girlfriend was driving at the time so the details are a bit sketchy at best.
I have bled the system from the 3 points and checked rad fan opporation.
The coolabnt cap makes a very faint hissing noise after switching the engine off which I assume is a slight leak but it is only slight, the tank is still pressurised several hours later.
I carried out a compression test yesterday and the results are as follows
Clyinder 1: 14.0 bar
Cylinder 2: 13.0 bar
Cylinder 3: 13.0 bar
Cylinder 4: 12.0 bar
Coolant was visable in cylinder 1 through the spark plug hole. there was also oil on the plug possibly explaining the higer compression.
I think I have narrowed it down to HGF or Inlet Gasket Faliure. The thing is. I cant find any information regarding Inlet manifold gasket failiure on the 135 model with the alloy inlet manifold. Is it a known problem on 135's?
If its not the inlet manifold, where is all my coolant going?
Replied by gotenks1321 on topic Inlet Manifold Gasket on a 135?
Posted 14 years 9 months ago #11055
It's not as common for the alloy manifolds to leak as it is for the plastic ones. Change the inlet manifold gasket and then see how it goes, cheapest option and fairly simple to do :yesnod:
Undo the bolts that hold the upper part to the lower, undo the bolts holding the lower part to the head and fit the new gasket. There are some electrical connections you'll need to take apart too but it's all pretty straight forward once it's in front of you :)
  • Visitor
  • Visitor
Replied by a Guest on topic Inlet Manifold Gasket on a 135?
Posted 14 years 9 months ago #11056
Brilliant, am I right in assuming the gasket is a different part to models with the plastic manifold? if so do you happen to know the correct part number?
Replied by David Aiketgate on topic Inlet Manifold Gasket on a 135?
Posted 14 years 9 months ago #11057
:welcome2:
Yep, the gasket is a different part number.
I believe it is LKJ100821, but my knowledge is on Fs, not TFs so you may need to confirm that.
  • Visitor
  • Visitor
Posted 14 years 9 months ago #11058
David Aiketgate;11057 wrote: :welcome2:
thanks very much
That is listed as the VVC inlet manifold gasket on rimmerbros so I think it will probably the correct one. I suppose its forth a shot at changing it for the grand total of £4 +P&P
Posted 14 years 9 months ago #11060
Griffo;11058 wrote: thanks very much
I believe that the lower part of the inlet manifold is the same in both instances.
With the plastic manifold it is usually possible to feel under the manifold at the throttle body end, and feel coolant there.
  • Visitor
  • Visitor
Posted 14 years 8 months ago #11178
Think it might be too late for the inlet manifold gasket.
Sniff test showed positive and oil is now a bit too mayoie if thts even a word
RUUUUUUUUUUUUUUUUUUSSEL!!!
Posted 14 years 8 months ago #11181
Griffo;11178 wrote: Think it might be too late for the inlet manifold gasket.
Oh, bum!:rolleyes2:
Time to create page: 0.521 seconds
