Hood or rear window replacement needed, Help!!!
- a Guest
- Visitor
Hood or rear window replacement needed, Help!!! was created by a Guest
Posted 14 years 8 months ago #11550
The first sunny day in a while (Sunday 7th Feb) and decided to lower the hood, only for it to make a loud pop and split....................Grrrrrr!
Can anyone suggest a supplier and fitter (because I'm not going into all the mularkey with extracting rivets!) in Sussex, Kent or Surrey.....if a bargain is to be had, may venture into London with a Police escort.
I will give Sonia Morris a ring as an option to replace the rear window, but will also consider replacing the hood.
Does Russell do fittings?
****Going into the dark side for a sec, has anyone seen an alternative colour to Black installed on a nightfire red MGF???*****
Thanks in advance
Lynne:mad:
Thanks in advance
Lynne:mad:
- adamelphick
Replied by adamelphick on topic Hood or rear window replacement needed, Help!!!
Posted 14 years 8 months ago #11551
The only colour that looks good on Nightfire apart from black is the Maroon hoods. Seen a few about and they look nice.
by adamelphick
Replied by David Aiketgate on topic Hood or rear window replacement needed, Help!!!
Posted 14 years 8 months ago #11552
I got ours done by Sonia, and was very pleased with the results.:yesnod:
You are a lot closer than I was!
Just had my rear window replaced by Sonia. Fantastic job and done very quickly. Was back home in Deal before I knew it! :woohoo:
by steve f
Time to create page: 0.492 seconds
