Cambelt
- a Guest
- Visitor
Just hope the weather is going to be nice the weekend.
bookearly;11933 wrote: All changed, new water pump, cambelt kit and coolant flushed.
Excellent! Just keep an eye on the coolant level.
Did you do a good bleed?
Also, even after bleeding from the three bleed points, it can take time to for all the remaining small pockets of air to come out,
and the level to settle down after a change.
I carry a 0.5litre bottle of premixed coolant - just in case.:yesnod:
As for the weather, I think it depends on where you are this weekend. Some areas for rain; some for sun:dunno:
- a Guest
- Visitor
Next on list is a new rear plastic screen. Will fit that myself.
bookearly;11945 wrote: The mechanic that did it, did an excellent job. Although he does not own a TF he runs a MG ZS and a ZR with a whacking great turbo (scooby eater). He kept it over night and ran it for a while to check levels were ok.
I got a new screen recently fitted by 'Sonia' nr. Heathrow. £100.
- adamelphick
Go Glass! You'll never look back (or rather you'll always be looking back hahah)
