Exhaust Manifold
  • bacchus
Exhaust Manifold was created by bacchus
Posted 14 years 7 months ago #12078
I have discovered I have a leaking exhaust manifold gasket. Part of the problem was a loose stud which I have tightened (45nm), but this has not solved my leak. I suspect the gasket is stuffed so my question is how much of a pain is replacing it? should I have a go at it? or do I go and find some unsuspecting mechanic to do the job? :dunno:
My F is a 1997 VVC with Aircon as most of you would know by the amount I dribble on about it. :whistle:
Also is there anything else I should do at the same time?
Craig
by bacchus
Replied by David Aiketgate on topic Exhaust Manifold
Posted 14 years 7 months ago #12079
Bacchus;12078 wrote: I have discovered I have a leaking exhaust manifold gasket. Part of the problem was a loose stud which I have tightened (45nm), but this has not solved my leak. I suspect the gasket is stuffed so my question is how much of a pain is replacing it? should I have a go at it? or do I go and find some unsuspecting mechanic to do the job? :dunno:
Craig
It's a reasonably easy job, Craig.:yesnod: You might have issues with studs coming out rather than nuts coming off.
Much easier than the inlet manifold.
Replied by Adam-Mgtf on topic Exhaust Manifold
Posted 14 years 7 months ago #12091
which gasket? is it flexi to manifold? there not to bad but i had a serious problem with my nuts... that big bar kept getting in the way
err
right
yeh the subframe is a pain and the extension bar on your ratchet will foul on the subframe... a good flexi attachment and some WD40 and you sorted :)
