Poorly fitting carpets...
- thatone1967
Morning all..
Want to try to fix my poorly fitting carpets this weekend..... I am told that the best fix is to put additional carpet under the factory fitted carpet, does this involve removing the seats... if so, are there any hazards, ie, do I need to disconnect the battery?
2003 MGTF Monogram Edition. Celestial Blue, Black Leather.No. 19 of 99 Built 11 Spoke Alloys. AP brakes.
by thatone1967
- adamelphick
thatone1967;12081 wrote: Morning all..
No need to remove the seats. You can 'peel' the carpet edge back from the door side and get at the insulation panel underneath. Remove this and use it as a template to cut your extra thickness bits. This is also a good time to check for damp and/or rust and rectify this.
Hope that helps!
by adamelphick
top notch info from adam, only thing i would add is if you decide to take the seats out to make things a little easier is to disconnect the battery.
You will have to disconnect the seat belt pretensioner wire to remove the seats and you don't want to mess with the pre-tensioner/airbag circuit... airbags in the face hurt! lol
just disconnect the batter, leave the current to discharge for 10 minuets (have a brew or undo the seat bolts) and then take the seats out simples
by Adam-Mgtf
Also have a look here:-
http://www.the-t-bar.com/showthread.php?t=41
:whistle::yesnod:
Time to create page: 0.552 seconds
