Anyone fitted GAZ dampers to an F?
  • Visitor
  • Visitor
Anyone fitted GAZ dampers to an F? was created by a Guest
Posted 14 years 7 months ago #12253
Bonsoir Garcon et Filles, Have any of you lovely people fitted Gaz dampers to their MGF? If so - what did you do about the washers that go both sides of the damper? Mine are dished and I can't make 'em fit properly.:dunno:
Thanks in advance :bye:
Replied by David Aiketgate on topic Anyone fitted GAZ dampers to an F?
Posted 14 years 7 months ago #12261
CheesyReich;12253 wrote: Bonsoir Garcon et Filles, Have any of you lovely people fitted Gaz dampers to their MGF? If so - what did you do about the washers that go both sides of the damper? Mine are dished and I can't make 'em fit properly.:dunno:
Thanks in advance :bye:[/QUOTE
Not exactly sure what you mean?
The washers on the bottom bush are dished - fitted outwards.
Or do you mean that the diameter of the damper is greater and fouls the washers?
  • Visitor
  • Visitor
Replied by a Guest on topic Anyone fitted GAZ dampers to an F?
Posted 14 years 7 months ago #12262
Couple of probs really, I can't remember what order the washers fit to the damper bolt. One is thicker than the other but whichever way I put them on (left/right or dished in/out) the washers won't clear the damper. I could grind a flat on the edge so as to clear the bottom of the damper but I'm wondering whether the wider washer goes front or behind the damper...............That doesn't make sense to me....and I wrote it:CJJ:
Posted 14 years 7 months ago #12263
CheesyReich;12262 wrote: Couple of probs really, I can't remember what order the washers fit to the damper bolt. One is thicker than the other but whichever way I put them on (left/right or dished in/out) the washers won't clear the damper. I could grind a flat on the edge so as to clear the bottom of the damper but I'm wondering whether the wider washer goes front or behind the damper...............That doesn't make sense to me....and I wrote it:CJJ:
The order on the bolt is - bolt through suspension arm. Then brake pipe bracket. Then spacer. Then small washer. then damper bottom fitting. Then bigger dished washer then nut.
Hope t5hat helps.
If the damper is fatter than standard, maybe you can increase the dish on the big washer with ball pein hammer?:dunno:
Replied by wilddog on topic Anyone fitted GAZ dampers to an F?
Posted 14 years 7 months ago #12264
recently fitted front & rears took off the top nut, spacer and rubber and fitted exactly how they came, should fit on with no issues....dial and click 3 times + and that should be plenty for a smooth ride, more u click the stiffer it will beome. The washers are all the same size as I recall? just check there are no old washers stuck to the underside of the suspension sill......one nut at the top on the old Rover suspension legs was cut off due to over tightening as it was jammed past the threaded end....
by wilddog
  • Visitor
  • Visitor
Posted 14 years 7 months ago #12267
David Aiketgate;12263 wrote: The order on the bolt is - bolt through suspension arm. Then brake pipe bracket. Then spacer. Then small washer. then damper bottom fitting. Then bigger dished washer then nut.
Hope t5hat helps.
that's a great help David, thanks, 1 wittle qwestion.......
Do the washers cup out, away from the damper (like ears) or cup in(effectively encapsulating the damper bush)? Mine just about fit if out but no chance at all if cupped in!
wilddog;12264 wrote: recently fitted front & rears took off the top nut, spacer and rubber and fitted exactly how they came, should fit on with no issues....dial and click 3 times + and that should be plenty for a smooth ride, more u click the stiffer it will beome. The washers are all the same size as I recall? just check there are no old washers stuck to the underside of the suspension sill......one nut at the top on the old Rover suspension legs was cut off due to over tightening as it was jammed past the threaded end....
Thanks Wilddog. Is yours a Mk1 or Mk2? I think the Mk2 has these cupped washers (though I may well be wrong)
Thanks again chaps.....most appreciated:yesnod::thanks:
Replied by gotenks1321 on topic Anyone fitted GAZ dampers to an F?
Posted 14 years 7 months ago #12337
The washers fit 'dish out' as it were :yesnod:
I have mine set on about 16 clicks. If you run too hard then you run the risk of cracking the suspension turrets and it's an engine out job to weld a plate in to strengthen them up :censored:
  • Visitor
  • Visitor
Posted 14 years 7 months ago #12338
gotenks1321;12337 wrote: The washers fit 'dish out' as it were :yesnod:
Cheers Dan, I shall dish mine out then, still have to grind the tops off though as there's not quite enough room!
I've been worned about the weakness in the turret and was planning on running about 8>10 anyway....don't want too hard a set-up.
Thanks again mate:thumbsup:
Posted 14 years 7 months ago #12339
No worries. I am slightly worried about why yours won't fit though. Any chance of a pic with it back together as best you can before you start grinding away?
As you can see from this pic, there should be plenty of thread left even with dished washers....
Time to create page: 0.539 seconds
