No Reversing Lights
No Reversing Lights was created by alias
Posted 14 years 7 months ago #13579
For some reason, I seem to have no reversing lights. I've changed both the bulbs, and still nothing.
Any ideas?
by alias
Replied by swerving on topic No Reversing Lights
Posted 14 years 7 months ago #13580
Have a look here... http://www.mgfcar.de/schedules/sb28.jpg seems a pretty simple wiring diagram, power from fuse 11 in the passenger compartment. seems to be share with the brake lights, so are they working???
If so, could be loom damage at the boot hinge area, or a switch problem which I would presume is near the gerbox, but thats beyond me I'm afraid!
Older but certainly not wiser!
Replied by David Aiketgate on topic No Reversing Lights
Posted 14 years 7 months ago #13581
Swerving;13580 wrote: Have a look here... http://www.mgfcar.de/schedules/sb28.jpg seems a pretty simple wiring diagram, power from fuse 11 in the passenger compartment. seems to be share with the brake lights, so are they working???
We had this problem and after checking the fuse, the bulbs and the loom, I changed the switch and voila - reversing lights again.
The switch button wears over time and is no longer depressed sufficiently to activate.
To check whether it is the switch you will need to disconnect the wires from the switch. With the ignition on bridge the two wires - if the reversing lights come on, it's the switch.
Although you can access the switch from the N/S/R wheel arch, you need to open up the engine access hatch under the parcel shelf to disconnect/reconnect the loom.
Replied by alias on topic No Reversing Lights
Posted 14 years 7 months ago #13583
I've still got brake lights - It was the first thing I checked :) Thank you for the diagram, I'll have a look once it has stopped raining.
David Aiketgate;13581 wrote: We had this problem and after checking the fuse, the bulbs and the loom, I changed the switch and voila - reversing lights again.
This might be a really stupid question, but what does the switch look like? Are they expensive to replace?
by alias
Replied by cjj on topic No Reversing Lights
Posted 14 years 7 months ago #13586
This is the reversing light switch. Approximately under the clutch slave cylinder, on the passenger side, towards the passenger seat.
[img][img]http://i625.photobucket.com/albums/tt333/CJJ326/MGTF/Technical/Clutch%20Change/ReversingSwitch01.jpg[/img][/img]
Posted 14 years 7 months ago #13591
CJJ;13586 wrote: This is the reversing light switch. Approximately under the clutch slave cylinder, on the passenger side, towards the passenger seat.
Thank you. Am I actually going to be able to get to that, or will I need to raise the car up and climb in under neath or something?
by alias
Posted 14 years 7 months ago #13592
It would be an underneath job for me, but as said, you need to go in from the top as well to disconnect it.
Posted 14 years 7 months ago #13594
CJJ;13592 wrote: It would be an underneath job for me, but as said, you need to go in from the top as well to disconnect it.
Oh dear... My car gets parked in the road, and I don't really fancy trying to climb underneath her where she is!
by alias
Posted 14 years 7 months ago #13599
Must be friends close by with a drive, maybe even a fellow f'er. You could use mine, but I think it might be a bit far.
Posted 14 years 7 months ago #13611
I think I'm going to leave it until I get to work tomorrow. There's loads of space, and I'm less likely to get run over.
Thank you for the offer, but you're definitely too far :)
by alias
Posted 14 years 7 months ago #13685
Flopsy is all fixed. The switch has had a good clean, and my reversing lights are back! Thank you all for your help :)
by alias
Posted 14 years 7 months ago #13686
Alias;13685 wrote: Flopsy is all fixed. The switch has had a good clean, and my reversing lights are back! Thank you all for your help :)
Good to hear, you're reversing safely again!:yesnod:
Time to create page: 0.415 seconds
