brake discs
FM :rolleyes:
You can buy kits that allow you to fit 266mm or 280mm discs to the rear. This wil give extra braking force and I have the 280mm ones fitted to mine, but you need the APs up front otherwise you will get a scary brake imballance.
CJJ;13840 wrote: Never really tried that make. Don't see any reason for them to be rubbish though. The only problem I have with unknown names is that sometimes they are made with lower grade metals which means that they corrode quicker.
Did you ever get the rear improvement tested, Clive?
I will try and remember this saturday.
FM :rolleyes:
