sealing loose Sensor Connections...
  • figo
  • Journeyman MGer
  • Journeyman MGer
  • Going Topless
sealing loose Sensor Connections... was created by figo
Posted 14 years 3 months ago #15102
Any idea how to seal these connections...
The clip is still GW ones and well are S**t and have now twice came loose...
Throttle Position Sensor... so its pretty much undrivable without it!
New ones are like hens teeth to buy..
Any ideas...
MG TF 135 135 Bhp
by figo
Replied by David Aiketgate on topic sealing loose Sensor Connections...
Posted 14 years 3 months ago #15104
Figo;15102 wrote: Any idea how to seal these connections...
Any ideas...
If the plug is coming out of the sensor, try a cable-tie around plug and sensor.
If the problem is that the plug isn't contacting the pins properly, you can induce a slight twist into each pin with a pair of needle-nosed pliers.:dunno:
Replied by adamelphick on topic sealing loose Sensor Connections...
Posted 14 years 3 months ago #15111
Was gonna suggest the pin bend method too (pipped to the post!) - be careful though as the 'Bakelite' case is very brittle i suspect and may crack.
Posted 14 years 3 months ago #15114
AdamElphick;15111 wrote: Was gonna suggest the pin bend method too (pipped to the post!) - be careful though as the 'Bakelite' case is very brittle i suspect and may crack.
Yep, 'SLIGHT' is the important word there!:lol:
Replied by Adam-Mgtf on topic sealing loose Sensor Connections...
Posted 14 years 3 months ago #15119
have you tried the type r owners mate? been pretty helpful to me so far :)
Time to create page: 0.498 seconds
