fitting windbreaker
fitting windbreaker was created by mgf04ron
Posted 14 years 3 months ago #15328
Hello again all , just fitted a new wind breaker works a treat. Problem , the tonneau cover no longer fits, it will not fit round the uprights which hold the breaker upright .Has onyone got round this peoblem if so & how,or do I need a different cover.
THanks oncs RON.:help:
Replied by David Aiketgate on topic fitting windbreaker
Posted 14 years 3 months ago #15338
MGF04RON;15328 wrote: Hello again all , just fitted a new wind breaker works a treat. Problem , the tonneau cover no longer fits, it will not fit round the uprights which hold the breaker upright .Has onyone got round this peoblem if so & how,or do I need a different cover.
Depends on which wind break you've fitted. Any pics?
Replied by mgf04ron on topic fitting windbreaker
Posted 14 years 3 months ago #15359
Thanks for interest I bought the windbreak from moss X part dealers in bradford when I lived near there.Fitting required removing the teebar & the uprights were fitted at each end by removing &refitting two bolts behind there, which were in line with the presstuds which hold the tonneau cover in place ,so it will no longer fit. I will try to get some pics soon , but since I had the glass rear window fitted its a devil of a job refitting it (just had a triple bypass) many thanks RON.
Posted 14 years 3 months ago #15360
MGF04RON;15359 wrote: Thanks for interest I bought the windbreak from moss X part dealers in bradford when I lived near there.Fitting required removing the teebar & the uprights were fitted at each end by removing &refitting two bolts behind there, which were in line with the presstuds which hold the tonneau cover in place ,so it will no longer fit. I will try to get some pics soon , but since I had the glass rear window fitted its a devil of a job refitting it (just had a triple bypass) many thanks RON.
Yes, I understand that the glass screen can make the hood sit higher when folded.
I had the MGR windbreak fitted which required the Tbar removal and then two new longer bolts in the fittings replaced two already there, so it sounds similar to yours. However I had no problem with the tonneau.:dunno:
I think a photo of yours will make things clearer.:yesnod:
Replied by mgf04ron on topic Windbreaker now works
Posted 14 years 2 months ago #15884
:o Thanks for help with my problem now sorted. So easy I had set the arms which hold the breaker upright when in fact they should have been horizontal .In this position they move the breaker 2" forward .problem solved. Must be a problem of age.
Cheers RON.:o
Posted 14 years 2 months ago #15885
MGF04RON;15884 wrote: :o Thanks for help with my problem now sorted. So easy I had set the arms which hold the breaker upright when in fact they should have been horizontal .In this position they move the breaker 2" forward .problem solved. Must be a problem of age.
Cheers RON.:o
Good news, Ron.:yesnod:
Time to create page: 0.605 seconds
