Mike Satur Metal Radiator Valve
- mikeknight
It's metal, also. Won't snap like the crappy plastic valve that's on there from the factory.
It included a bleed nipple so you don't have to take the whole thing off to bleed it, you just turn the nipple. Oo-er.
- mikeknight
I took it off and it immediately squirted me in the face. :prrr:
Watching me work on my car is like watching a comedy sketch, most of the time.
Replied by David Aiketgate on topic Mike Satur Metal Radiator Valve
Posted 14 years 3 months ago #15408MikeKnight;15406 wrote: Possibly the best thing I've bought from Mike!! It made getting the air out of my system after changing my underfloor pipes an absolute breeze! Also helps with draining coolant if you put too much in the expansion tank (like I did).
Yeah, I got one of those, only to find that the thread is different in some aftermarket radiators! Typical!
- mikeknight
Posted 14 years 3 months ago #15411MikeKnight;15410 wrote: If you had a tap and die set you could make your own thread, though you'd then risk making the opening ever so slightly too large for the bolt.
Yep, That's what I did but I was never really happy with the fit. When I went to use the bleed screw the whole thing would unscrew. In the end I took it off again and there's a stainless bolt in there now.
- a Guest
- Visitor
- mikeknight
Tigger;15423 wrote: I was always worried about stripping the thread out of the rad
I've found that tightening just the nipple until you feel "a good torque" on it also tightens the main body to the correct value.
Alternatively find a small torque wrench. I think the value for the main body is 7.
Can I replace the radiator bleed screw with the MS one without spilling a lot of coolant everywhere? or do I need to drain the system first?
Cheers
Posted 14 years 2 months ago #15618Rekrab;15617 wrote: I knew there was something I'd forgotten to fit
Cheers
If you have the new one handy and stick your finger over the hole while you swap old and new in your hand, then you will be able to bleed the small amount of air out of your shiny new bleed nipple.
- mikeknight
Might want to buy a very small bottle of ready mixed OAT from Halfords to top up what you lose. Always handy to have a top-up on hand anyway.
Fitted today and wasn't as bad as I thought. There was a slight issue with the Heater Bypass/Return bleed bolt which looks like the previous owner/garage has rounded off
Looking on Rimmer Bros now for a replacement
Thanks again
