How do I get to my clutch arm to spray wd40 on it?
How do I get to my clutch arm to spray wd40 on it? was created by thatone1967
Posted 14 years 3 months ago #15464
Am round a friends at the mo, we are wanting to spray Wd40 on the clutch arm to free it off, how do we access it?
2003 MGTF Monogram Edition. Celestial Blue, Black Leather.No. 19 of 99 Built 11 Spoke Alloys. AP brakes.
Replied by David Aiketgate on topic How do I get to my clutch arm to spray wd40 on it?
Posted 14 years 3 months ago #15465
thatone1967;15464 wrote: Am round a friends at the mo, we are wanting to spray Wd40 on the clutch arm to free it off, how do we access it?
To access the clutch arm you'll need to remove the engine cover(under the parcel shelf.)
ps You need to use a penetrating oil(like plusgas) not wd40
Replied by bryan young on topic How do I get to my clutch arm to spray wd40 on it?
Posted 14 years 3 months ago #15468
David, as our expert in all things F & TF will squirting Plusgas on the clutch arm free it??? Bryan
Posted 14 years 3 months ago #15471
Bryan Young;15468 wrote: David, as our expert in all things F & TF will squirting Plusgas on the clutch arm free it??? Bryan
The arm is usually seized where it enters the bellhousing and working a penetrating oil into that area and manipulation can often free it off. Once you get it moving again, then you need to keep it lubricated.
Here is someone's ingenious effort at doing that.
taken from below
(Btw, that bit in the OP about Plusgas was my addition.:doh:
It should have been added to my reply not the original post.:yesnod:
As a mod you get extra buttons on posts and I pressed the wrong one.:yesnod:) I've now put it where it should have gone in the first place :doh:
Posted 14 years 3 months ago #15477
David Aiketgate;15471 wrote: The arm is usually seized where it enters the bellhousing and working a penetrating oil into that area and manipulation can often free it off. Once you get it moving again, then you need to keep it lubricated.
taken from below
Doh!! Doh! glad i am not the only one!! That is a great idea you ought to patent it
Posted 14 years 3 months ago #15478
Bryan Young;15477 wrote: Doh!! Doh! glad i am not the only one!! That is a great idea you ought to patent it
If it was my idea, I would!
Time to create page: 0.497 seconds
