Head Gasket - just when things were going ok
Head Gasket - just when things were going ok was created by wilddog
Posted 14 years 2 months ago #15571
Hi,
You know when all is ok something is bound to happen, well, noticed a drop ever so slight (1cm) in the expansion bottle, topped it to the seam. This happened twice. Took the engine bay cover off and found a trickle of water on the top join between the gear box and cylinder head.
Since this I wiped this area clean and re-examined today and found a trickle of water at the front of the clyinder head and main block. No mayo in the engine or dip stick or the coolant cap all clean. No raise in water or oil temp, checked hoses no leaks and air locks either, so once a pressure test is completed then I will know further.....
I read through all the old receipts (2 years old) as it mentioned a head gasket and skimmed head using the upgraded gasket kit, but when taking out all the sound proofing to access the engine bay cover I found a small plastic bag.
This bag contained 2 stainless steel dowels, I can only assume these were for the new kit and never used!
Waiting on the mobile mechanic Russell to arrange a date for a fix...........and while he is at it, he offers option packages, i've gone for C as it includes cam belt change, water pump, thermostate etc so the road will be a fair quieter for the next few weeks.
any other ideas or mechanics please post a reply
regards
by wilddog
Replied by David Aiketgate on topic Head Gasket - just when things were going ok
Posted 14 years 2 months ago #15574
wilddog;15571 wrote: Hi,
regards
Is the coolant leaking under the throttle body area? If so, you can get that effect if the inlet manifold gasket is leaking. It drips off the manifold and runs around the seam between the head and the block.
Replied by wilddog on topic Head Gasket - just when things were going ok
Posted 14 years 2 months ago #15578
Hiya, how r you both?,
I moved on since the squeaky suspension (no more squeak) to coolant issues :)
I very much appreciate the information: sorry to be sounding mechanically dud (learing curve increasing) does water run through the inlet manifold? could this be the reason for no mayo effect? and the the two metal dowels I found could be anyones guess I suppose :) would the new gasket kit to your knowledge come with more than 2 dowels?
would this only require the inlet gasket replacing? sorry for the questions
I think I am getting that syndrome called 'coolant where have you gone' (latin version 'Aquaous donas gonas' ).
kindest regards to you both
keith
by wilddog
Posted 14 years 2 months ago #15579
I nearly forgot, I will check the throttle body area....doh!
by wilddog
Posted 14 years 2 months ago #15585
Water runs up to the face of the inlet manifold and the manifold blanks it off. Any deformation of the manifold or degradation of the gasket, leads to coolant escaping. Usually at the lower left hand side of the manifold(looking from the rear of the car). You can often feel liquid/ dampness if you run a finger along the underside of the manifold. Watch out for hot engine.
A new gasket kit comes with only one set of steel dowels.
Posted 14 years 2 months ago #15600
Thanks for the valuable information, checked the level by marking the expansion bottle and driving round last night. This evening I checked the mark and now the coolant in the expansion bottle has risen above the mark? No damp along the inlet manifold?
What a laugh :0 cannot figure this one out....what is going on, (jibber jibeer) as I laugh out loud (head gaslet maddness), neighbours know I am mad, now this puts the icing on the jam sponge cake, Mmmmm nice. Just have to wait for russell to contact me and let him figure this one out.
by wilddog
Posted 14 years 2 months ago #15604
wilddog;15600 wrote: Thanks for the valuable information, checked the level by marking the expansion bottle and driving round last night. This evening I checked the mark and now the coolant in the expansion bottle has risen above the mark? No damp along the inlet manifold?
If the coolant level rises, it usually means air/gas in the cooling system. If it falls again when the system cools, that is a sign of gas/air, as gas/air expands with heat.
Posted 14 years 2 months ago #15616
Many thanks for the info, been chatting to russell and hopefully all will be repaired in the next couple of weeks
much respect for the help
by wilddog
Posted 14 years 2 months ago #15619
wilddog;15616 wrote: Many thanks for the info, been chatting to russell and hopefully all will be repaired in the next couple of weeks
Russell will see you right. A top bloke, came all the way to Carlisle to fit me a new head gasket!:yesnod:
Tell him, I said 'Hi', and that, 30,000 miles later, it's still going strong. (Touch wood.:lol:)
Replied by bryan young on topic Head Gasket - just when things were going ok
Posted 14 years 2 months ago #15624
David Aiketgate;15619 wrote: Russell will see you right. A top bloke, came all the way to Carlisle to fit me a new head gasket!:yesnod:
Dont tempt fate!!!!! , mind you aren't Russell's jobs guarenteed for life!!, he is a great bloke, saved so many MGFs and TFs from a fate worse than death
