Alloy Wheel size confusion
- a Guest
- Visitor
The alloy fitment guides show the MGF as having a PCD of 95.75 but just put the guage across mine and they are 100. No adapters fitted as far as I can see.
The question I've now facing is that if the PCD is different how do I know what offset etc to look for? Or am I being dull? - won't be the first time:whistle:
Cheers
Mel
the standard PCD is 95.25, have you measured from stud centre to stud centre? It is possible that someone has fitted alternative hubs, such as from a MgZR which does have a PCD of 100.Tigger;15897 wrote: Have currently got 17" Mille Miglia alloys fitted to my '02 TF, but thanks to the council's lack of road maintenance I now have to get a new set.
Cheers
Mel
Quite possible if you have Mille Miglias fitted, because I don't think they do A PCD of 95.25. The offset will still be the same as standard. I wouldn't be surprised if the pcd and offset are marked on the inside of the wheel.:dunno:
If so they might have adaptors fitted to accept a 100mm PCD.
MG TF LE500 27 of 500
why not take em to a local quick fit?
a helpful mechanic may mesure them properly for you to remove all doubt?
- a Guest
- Visitor
Thanks for all the replies, apologies for wasting your time though.
No problemo!:lol:Tigger;15923 wrote: Panic over - PCD ok seems the problem lies with my eyesight. Got the local tyre suppliers to check the measurement for me = 95.25. We couldn't see anything on the wheel, which didn't help.
