Anyone on here ever done a DIY wheel bearing change?
- thatone1967
Anyone on here ever done a DIY wheel bearing change? was created by thatone1967
Posted 14 years 1 month ago #159362003 MGTF Monogram Edition. Celestial Blue, Black Leather.No. 19 of 99 Built 11 Spoke Alloys. AP brakes.
Replied by David Aiketgate on topic Anyone on here ever done a DIY wheel bearing change?
Posted 14 years 1 month ago #15937Machine Mart do one for just over a tenner. Herethatone1967;15936 wrote: Need to replace one of the rear wheel bearings, I have a friend who does a lot of mechanical goods for me, he is happy to undertake this, BUT, we need to get hold a "wheel bearing puller".. anyone know if I can hire these any where, or can it be done without it?
- a Guest
- Visitor
Replied by a Guest on topic Anyone on here ever done a DIY wheel bearing change?
Posted 14 years 1 month ago #15938Please Log in or Create an account to join the conversation.
- adamelphick
Replied by adamelphick on topic Anyone on here ever done a DIY wheel bearing change?
Posted 14 years 1 month ago #15943Please Log in or Create an account to join the conversation.
- a Guest
- Visitor
Posted 14 years 1 month ago #15947AdamElphick;15943 wrote: The bearing is unbelievably tight. I took Meg's front hubs both to a Mini specialist as they are the same as a Metro. The guy almost broke his press as the pressure needed to press them in was so high!
Mmmm - begs the question, finer engineering tolerances than the Germans or did they just make the bearing too big:whistle:
- thatone1967
Replied by thatone1967 on topic Anyone on here ever done a DIY wheel bearing change?
Posted 14 years 1 month ago #15952Tigger;15947 wrote: Mmmm - begs the question, finer engineering tolerances than the Germans or did they just make the bearing too big:whistle:
Much as I love my car, judging by the build quality of the rest of the car..... I think we all know the answer....
- adamelphick
Posted 14 years 1 month ago #15957When the rears needed doing I got two off a really low mileage breaker!
- thatone1967
Posted 14 years 1 month ago #15964Off. The top bolt is just turning, even with the assembly supported.
Any thoughts people?
- adamelphick
Posted 14 years 1 month ago #15965Please Log in or Create an account to join the conversation.
- thatone1967
Posted 14 years 1 month ago #15967UpdateAdamElphick;15965 wrote: Only way I know is to jack the car up using that as the jacking point so to speak - so as to jam the spindle back in the hole... failing that its cut the nut off I'm afraid and then maybe you'll need a new balljoint as well!
Have managed to get it off, taken it to a local mechanic
Turns out, the seized bearing has worn away the part it fits
Into, so I need to replace the "axle".
- a Guest
- Visitor
Posted 14 years 1 month ago #15968thatone1967;15967 wrote: Update
Sorry to hear that - always seems to end up that way when a job starts going wrong. :shake: You probably already use them but just in case follow the link - they'll have the hub you need...
http://www.mgfntfbitz.co.uk/
thoroughly recommended.
- adamelphick
Posted 14 years 1 month ago #15970thatone1967;15967 wrote: Update
Damn - dab news - this is the reason they are so tight to try and stop this - but once seized they have great force on them to spin
