Hub carrier broken, pehaps.
  • Visitor
  • Visitor
Hub carrier broken, pehaps. was created by a Guest
Posted 14 years 3 weeks ago #17507
I took the Blue Meanie in for new tyres today and got laser alignment done.
Looks like the nearside rear has had a smack at some point. Turns out it's almost perfectly upright with no camber. They showed me that all the rods and bars look straight so best guesstimate is that the hub carrier is bent.
The guy at the tyre depot said that it's safe and would pass it's MoT but that it will wear the shoulder of the tyre faster and that if I was really giving it some then the back end wouldn't be as planted as it should be on right handers.
Anyone know how big a job changing the hub carrier would be and how much a new hub carrier would cost?
Replied by David Aiketgate on topic Hub carrier broken, pehaps.
Posted 14 years 3 weeks ago #17523
Sorry Andy, I can't help much on this one.
TBH, i would have thought a damaged carrier would give you wheel wobble.:dunno:
  • Visitor
  • Visitor
Replied by a Guest on topic Hub carrier broken, pehaps.
Posted 14 years 3 weeks ago #17530
I think I need to jack up that corner and see if the wheel is wobbling and then take the wheel off for a closer look.
Posted 14 years 3 weeks ago #17532
Andy1970h;17530 wrote: I think I need to jack up that corner and see if the wheel is wobbling and then take the wheel off for a closer look.
Also measure up all the components of the suspension and compare them to the other side. It may give you a clue.
Replied by cjj on topic Re: Hub carrier broken, pehaps.
Posted 14 years 3 weeks ago #17603
If it's just bent it may not wobble.
Time to create page: 0.472 seconds
