A new feature on my TF
Do you think this is right? Might explain why I've had a bit of wandering on straight roads.
Video
Angel to Devil in 0.2 seconds...[SIGPIC][/SIGPIC]
David Aiketgate;17095 wrote: Oi, stop using foul language or I'll give you one!
I have tightened the hub nuts. Got 1/8th of a turn and it is a lot better now.
- adamelphick
adamelphick wrote: If it needed that much of a turn then it may have spun in the hub and damaged it - happens a lot with Metros. Might be best with a new hub and bearings if not sure as if it is scored the bearing will never be as tight as it should be.
That's it Adam, Cheer him up!:lol:
- bryan young
cjj wrote: We have a press at work, so some new bearings me thinks.
Madmax had the same problem on his TF, the "big nut" was loose, the bearings had turned in the hub, new drive flange, bearings set and big nut tightened to 150lbs/ft torque sorted it (Russell Walsh did the fitting) The cause was due to the nut not being spiked into the locking groove properley!!!:evil:
Mine was properly secured, just wear methinks.
The car behaved very well today.
