Rear brakes problems.
Rear brakes problems. was created by talkingcars
Posted 14 years 2 weeks ago #18163
My handbrake light has always flashed on and off, apparently due to the lever not going down correctly.
Also the ABS light sometimes stays on if the car hasn't been used recently but normally clears fter the second time of starting.
As the MOT is due soon I need to sort this.
What is the most likly cause, sticking cable or caliper?
The car sat for 5 years until being sprung back into life late last year.
Last Edit:14 years 2 weeks ago by talkingcars
Last edit: 14 years 2 weeks ago by talkingcars.
Replied by rough luck on topic Re: Rear brakes problems.
Posted 14 years 2 weeks ago #18164
The rear calipers are really prone to sticking, more so on the handbrake pull arm
If it isnt that then the cables are on there way out,its less likely though
Try the calipers first as the cables are a real pain to change,
With it being stood the abs ring around the drive shaft might have rust round it, just give it a quick wire brush an see how it goes
Replied by mgfmad on topic Re: Rear brakes problems.
Posted 14 years 2 weeks ago #18165
If your caliper handbrake mechanism is siezed, have a go using Davids guide -
Click
It worked when I tried it on my MGF:)
MG TF LE500 27 of 500
by mgfmad
Replied by talkingcars on topic Re: Rear brakes problems.
Posted 14 years 2 weeks ago #18166
Cheers peeps - having looked at the guide, although I'm sure I could do it, given the time and space, I think I'll invest in a pair of new rear calipers for a start, there are some new ones on eBay for throw away money at the moment.
I watched my son and his ex stepdad change the handbrake cable on my sons metro, I can only imagine the cable on the F is similar but even more inacessable.
Posted 14 years 2 weeks ago #18172
working on either end of the cables is quite easy, the problem comes were the cables enter the rear bulk head, the plate is right between the bulkhead and rear subframe bottom bar, it holds 4 cables in total, the two rear brake ones and two gear cables, the small bolts that hold it on are normally in a bad way which doesn't help
Replied by David Aiketgate on topic Re: Rear brakes problems.
Posted 14 years 2 weeks ago #18174
Well after driving through the tunnels of Newcastle with the unpleasant smell of burning brake pads, looks like I need to strip one of the rear callipers again. It's definitely the handbrake lever binding slightly.
Posted 14 years 2 weeks ago #18176
I bought a new rear caliper as a spare on ebay the other day £17 bargin :)
Posted 14 years 2 weeks ago #18179
How much?:blink:
Posted 14 years 2 weeks ago #18185
Errr no i LIED ...lol
I just checked
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=180570745969&ssPageName=STRK:MEWNX:IT
£17.51
the exact same that are on a buy now for £75
Posted 14 years 2 weeks ago #18186
rough luck wrote: Errr no i LIED ...lol
I just checked
£17.51
I feel slightly better now. I need the nearside!:)
Posted 14 years 2 weeks ago #18204
Today, I will be mainly taking off my rear n/s brake calliper!
Posted 14 years 2 weeks ago #18219
When I removed the nearside rear wheel, I could see that the handbrake lever wasn't returning fully.
It wasn't a lot, but enough to prevent the pads from releasing fully from the disc. Hence the nasty burny smell!
I realised that I could carry out most of this without taking the calliper off the car.
I dismantled the handbrake lever and disconnected the cable as in the how-to. I then unbolted the calliper from the carrier, so that it was only attached by the brake hose.
I noticed that the rear pad was also binding in the carrier. I filed the edges of both pads until they moved freely in the carrier.
I sprayed white lithium grease passed the seal and manipulated the lever until it became free again.
I cleaned up any overspray, and then rebuilt the lever mechanism. Reconnected the cable and refitted the calliper to the carrier.
Job done, Road tested the car and brakes/handbrake working well and no burning smell!;)
Time to create page: 0.535 seconds
