window seal
- rough luck
- Site Sponsor
- Jon
Although I have heard of people cutting the seal at the end and sliding in rubber pipe (The clear flexible stuff) it sort of fills out the old seal
Clive will be alone soon, I know he's up to speed on seals an window fitting as he was doing everyones at the service day, he might have a few more ideas for you
Is there a kink or does the seal not mate up completely with the winscreen seal? You can adjust the ones one the hood. There is a small nut on the inside leading edge of the first hood seal. If you loosen this you can slide it forwards or backwards.
If you can get a pic of the problem I might be able to help a bit more.
- bryan young
rayb wrote: will try to get a pic of the problem tomorow, the passengers side is fine, but the drvers side looks flat, im not sure but would a mgtf seal be better, as im sure rover updated the window seal, would it still fit the mgf
Inserting a plastic pipe inside the seal works well and has been done a lot to pack out the seal (its the small air pipe that is used in fish tanks)
Check out the prices of a replacement seal, if its the one that goes from one side, across the head of the windscreen and down the other side? they cost "an arm & a leg" :whistle:
