F to TF air intake box under bonnet
Replied by swerving on topic Re: F to TF air intake box under bonnet
Posted 14 years 1 week ago #18697
Adam I did this mod last winter,
I found the only way to get the old one off is to cut it, I tried various cutting methods, even down to the wife's secateurs, in my frustration. Perseverance is what's needed, oh and plenty of coffee too.
Putting the new one on is easier but not that easy to put the bolts in if I remember correctly some have captive nuts and others you need to put a nut on. If I remember right I ended up with one nut taped to a large flat screwdriver a real pig of a job but it sorts the water leaking problem out.
Oh and mine's a Mk II as long as it has the box shaped inlet it'll leak, particularly if you park it facing uphill.
Prior to refitting I would suggest ample mastic around the welded joints as nibe leaked there too.
Well documented on .org I think
If you need more help give me a shout I will pm you my moby number
Peter
Older but certainly not wiser!
Replied by adamelphick on topic Re: F to TF air intake box under bonnet
Posted 14 years 1 week ago #18707
swerving wrote: Adam I did this mod last winter,
Peter
Thanks Peter - copious amounts of mastic going on the seal don't worry! Never want to do it again EVER! LOL
Posted 14 years 3 days ago #19031
Well managed to sort the air intake today! Woohoo
It started spitting as soon as I opened the bonnet so undeterred I got the garden brolly out and put it up and immediately the rain stopped LOL... I'll add the How To later!
Replied by David Aiketgate on topic Re: F to TF air intake box under bonnet
Posted 14 years 3 days ago #19032
Looks good!:cheer:
Posted 14 years 3 days ago #19033
Plus a little extra is that although Meg's air-con is STILL only half installed I found the connector that powers up the front unit - and voila - recirculated air!
Posted 14 years 3 days ago #19052
adamelphick wrote: Plus a little extra is that although Meg's air-con is STILL only half installed I found the connector that powers up the front unit - and voila - recirculated air!
Air is good! Even recirculated.
Time to create page: 0.544 seconds
