Leaks
I used 5mm tubing.Laz1957 wrote: I want to try the 'silicone tubing' fix on the window seals.
What diameter tubing is best for the job please?
Then again, that's all I had.:lol:
I don't have leaks anyway, must work!
The following user(s) said Thank You: Laz1957
Laz1957 wrote: Aplogies for my thickness - is the 5mm the external or internal diameter of the tubing?
Just been and measured it and it's 8mm outside diameter, not 5mm.
I do have some 11mm outside diameter pipe, but that was just a bit too much.
Time to create page: 0.499 seconds
