Heated rear window
James
I've been doing loads of photos for a how to........
- adamelphick
talkingcars wrote: I've just been connecting the switch and relay for the heated rear window of the hardtop, the only info I could fid was for a post face lift F but mine is a pre face lift, any suggestions as to where the relay goes, is it the empty yellow socket on the bottom right of the underdash fuce box?
James
If you have the yellow and red relay, then the HRW relay fits in the 3rd postion.
If not, the socket will be in the loom tucked behind the fusebox.
adamelphick wrote: I remember when I did Meg's glass rear screen I just bunged a relay in the spare socket - whichever one it was! Does this pic help at all - you can just about see the relays:
You can see the yellow and red ones.......
david aiketgate wrote: If you have the yellow and red relay, then the HRW relay fits in the 3rd postion.
Perfect, that even saves me trying to work out which way around the relay goes.
If you can't find it behind the fuse box, try wwwwwwaaaaaaaaaaaayyyyyyyyyyyy up the steering column. That's where mine was taped up!talkingcars wrote:
