Electrics help with heated seats
Anyway, for a while I have had a pair of TF OEM heated seat switches and plan to use them instead of the 2 heat setting switches that come with the kit. Now obviously in doing so I will loose the HI/LO heat settings the kit offers..
My plan therefor, is to wire up the kit to the OEM switches using the HI setting but also add some kind of potentiometer to enable a degree (no pun intended ) of heat control. The specs quote: Stage II: 90 watts (2 seats) so I assume that means each seat is 45 watts; therefor am I right in thinking I need to be searching for a potentiometer that can handle in excess of 45 watts and 12volts and assuming I can find one, it would just fit in-line on the +ve rail to the seat element?
**EDIT**
Something like this? (Although I have no idea if its up to the job!)
http://www.maplin.co.uk/Module.aspx?ModuleNo=2208
my friend installed some in his Exige for when he has the roof off in the winter and left them on and killed a battery! lol!
Replied by David Aiketgate on topic Re: Electrics help with heated seats
Posted 13 years 11 months ago #19616I don't think your cunning plan will work, because I seem to remember that the two settings are actually powering different sized elements in the pads, rather than just more power through one set of elements.:shrug:Kameleon wrote: So today I am ordering the waeco heated seat kit after reading the how-to by David, which incidentaly makes it look really simple.... that means there is almost 100% chance I'll still be doing it Sunday night but alas!
Replied by Kameleon on topic Re: Electrics help with heated seats
Posted 13 years 11 months ago #19618Which setting do you use more often? Is the hottest setting too warm or nice and toasty?
Replied by Tigger on topic Re: Electrics help with heated seats
Posted 13 years 11 months ago #19619Kameleon wrote: Hmm that is a bit of a bummer but not a show stopper, I wonder how the variable kit waeco produce works, I just assumed it was a switch replacement and didn't fancy paying £30 for something I can make with some bits from Maplins!
I find the lower setting still a bit too warm after a while but the other half has the seat on the higher setting all the time (guess I'm just hot stuff :whistle: )
Posted 13 years 11 months ago #19620We use the no 1 setting most. I sometimes use 2 if I'm getting into the car 1st thing after a -10 night!Kameleon wrote: Hmm that is a bit of a bummer but not a show stopper, I wonder how the variable kit waeco produce works, I just assumed it was a switch replacement and didn't fancy paying £30 for something I can make with some bits from Maplins!
Posted 13 years 11 months ago #19632Please Log in or Create an account to join the conversation.
