R800 Wiper Stalks
Finished my circuit for intermittant wash wipe, Simply it takes the output from the intermitant speed selector and based on that triggers a Single Wipe, The speed selector varies the time between each wipe.
Heres the circuit
Whilst this will work the resistor values in the stalk are far to low and close together to make any real difference to the time between wipes, Currently it can be varied between 1 to 1.5 second pulse's
If we had an output of up to 100k then our range would between 1 to 30 seconds.
My next step is see how i can change the resistors in the stalk, failing that i'll have to do it via a Microprocessor instead but that'll push the cost right up.
I'll update this thread when i've got a stalk apart.
Heres the circuit
Last Edit:13 years 10 months ago
by psymon
Last edit: 13 years 10 months ago by psymon.
Sounds a good start!:yesnod:
The circuit diagram whizzes completely over my head, but I'll take your word for it.:rofl:
Keep on it - would be ideal if you can come up with a variable intermittent wipe facility
MG TF LE500 27 of 500
by mgfmad
Sheila's previous car was a Peugeot and that had an automatic setting on the wipers.
when it rained the wipers started in auto and then wiped at the appropriate rate for the heaviness of the rain.
It was great until the screen over the sensor got mucky and then... chaos ensued.:lol:
But as long as you kept a cleaning cloth to keep the sensor area sparkling, it worked.
I've got auto wipers on my BMW, doesn't seem to suffer from dirt on the screen but does hate the wrong sort of rain, it can't cope with fine rain at all.
Same unit has the Auto Headlights sensor and autodiping rear view mirror as well, Keep eyeing it up thinking how do i get that in the F with out losing the interior lights
by psymon
- adamelphick
