HRW wiring
HRW wiring was created by talkingcars
Posted 13 years 10 months ago #20126
Ok, so we get the switch in,
we eventually get the relay in because the fuse board has moved and neeed bending back,
we got the battery charged and
the engine started.
But the rear screen doesn't clear!
Yes, I've connected the plug to the screen.
Yes, I've switched the switch and it's lit up.
Even checked the relay clicks.
Then I discover that one of the wires to the glass has become detatched.
HOW DO I REATTACH IT?
Last Edit:13 years 10 months ago by talkingcars
Last edit: 13 years 10 months ago by talkingcars.
Replied by David Aiketgate on topic Re: HRW wiring
Posted 13 years 10 months ago #20127
talkingcars wrote: Ok, so we get the switch in,
the engine started.
It depends how good you are with a soldering iron.:yesnod: If you resolder you need to be aware of the potential for cracking the glass. )Make sure the glass is as warm as you can get it before you start.
I have heard of conductive adhesive that could be tried.:shrug:
Posted 13 years 10 months ago #20128
Replied by talkingcars on topic Re: HRW wiring
Posted 13 years 10 months ago #20132
Thanks David, I didn't know such stuff was avalible. I've now done an eBay search and found
this stuff
Posted 13 years 10 months ago #20137
Let us know how you get on with it.:yesnod:
