cats
  • rayb
cats was created by rayb
Posted 13 years 9 months ago #20722
hi could any one tell me if the MGF VVC cat is the same as a standard 1.8 cat 95-200 model year. thanks
by rayb
Replied by rough luck on topic Re: cats
Posted 13 years 9 months ago #20724
I think they are the same although ebay prices are from way too cheap with an unknown maker to £200
Best place I found are local motorist places normally about £40-£45
Although you may need a bolt set too and a new set of gaskets, the bolts normally rust up an seize
Replied by David Aiketgate on topic Re: cats
Posted 13 years 9 months ago #20727
Yep, there's only two cats MK1 and MK2/TF. MK1 is straight;mk2 has a 90 bend on one end.
Get a 'Cat saver' kit from ebay, longer stainless bolts and long nuts. Then grind the old nuts off. Saves hours!
Replied by Laz1957 on topic Re: cats
Posted 13 years 9 months ago #20730
Can you fit a MK 2 cat to a Mk 1?
That would then mean that I could the fit a Mk 2 exhaust without needing the extra 90 degree pipe?
by Laz1957
Posted 13 years 9 months ago #20731
I think you could but you would also need a 22mm lambda sensor plug, as the TF has a post CAT sensor which the MK1 doesn't
Posted 13 years 9 months ago #20742
Ahh - 90 degree pipe most probably an easier option then ;)
by Laz1957
Replied by Rich in Vancouver on topic Re: cats
Posted 13 years 9 months ago #20743
Not necessarily. The plugs are cheap.
Posted 13 years 9 months ago #20744
Just block the lambda sensor hole with a suitable bolt.,:yesnod:
Last Edit:13 years 9 months ago by David Aiketgate
Last edit: 13 years 9 months ago by David Aiketgate.
Replied by gsxrbob on topic Re: cats
Posted 13 years 7 months ago #22840
is the 90 deg pipe a de cat pipe seen one on ebay classed as lotus elise my mate says 5 to 10 bhp extra 10 min change over for mot sounds good ?
by gsxrbob
Posted 13 years 7 months ago #22844
You would need a decat pipe with the 90 degree bend, but just because it has a 90 degree bend doesn't make it a decat, just a mk2 cat. The jury is out on whether decatting a TF helps or hinders power output.
What is undisputed is that the exhaust will be a lot noisier.
Replied by cjj on topic Re: cats
Posted 13 years 7 months ago #22848
If you were changing them anyway then it would probably be better fitting the Mk2 cat and backbox. You would just need a blanking bolt for the post cat hole as already said.
You can buy cheap cats if your car is before 1st Mar 2000 as cars after that date need a cat with a type aproval which bumps the price up.
Posted 13 years 7 months ago #22867
why and what type aproval?
by gsxrbob
Time to create page: 0.551 seconds
