Bloody leak
Bloody leak was created by Tigger
Posted 13 years 9 months ago #21195
Well, been raining overnight - found this when i went to put the seats back in after changing the T bar -
http://i868.photobucket.com/albums/ab247/Wynnstay/Hood%20Leak/SDC10309.jpg
Rust looks worse than it actually is.
water was running down the bulkhead having dripped (slight understatement) from here -
http://i868.photobucket.com/albums/ab247/Wynnstay/Hood%20Leak/SDC10310.jpg
traced it back up and found water coming in through the velcro at the bottom of the rear window, running around the lower edge -
http://i868.photobucket.com/albums/ab247/Wynnstay/Hood%20Leak/SDC10311.jpg
Strange thing is water comes in the same place on the passenger side but doesn't end up in the car.
any ideas how to sort this?
by Tigger
Replied by adamelphick on topic Re: Bloody leak
Posted 13 years 9 months ago #21197
The water that invariably gets in the soft top 'seams' is supposed to go round the outer channel in the bodywork and then get deflected out to the door jams by the rubber seal... maybe your seal is a bit crushed or bent in even allowing the water to come in rather than be deflected out?
The following user(s) said Thank You: Tigger
Replied by Tigger on topic Re: Bloody leak
Posted 13 years 9 months ago #21198
adamelphick wrote: The water that invariably gets in the soft top 'seams' is supposed to go round the outer channel in the bodywork and then get deflected out to the door jams by the rubber seal... maybe your seal is a bit crushed or bent in even allowing the water to come in rather than be deflected out?
Thanks - will go and have a look if there's a difference between the seals.
by Tigger
Posted 13 years 9 months ago #21202
Excellent call - looks as if it's fixed!
Had to release the rear of the hood and pull the seal towards the back of the car - the seal just in front of the main hood pivot had somehow moved forward from the proper position. :shrug:
Pouring with rain and no water coming into the car. :woohoo:
by Tigger
Replied by David Aiketgate on topic Re: Bloody leak
Posted 13 years 9 months ago #21203
Good call, indeed!:cheer:
Time to create page: 0.482 seconds
