Rear Wheels
Rear Wheels was created by mahnek
Posted 13 years 9 months ago #21223
Car has been sat around for some time, tried removing rear wheel but no joy. Have removed four wheel nuts any sugestions
by mahnek
Replied by bryan young on topic Re: Rear Wheels
Posted 13 years 9 months ago #21225
mahnek wrote: Car has been sat around for some time, tried removing rear wheel but no joy. Have removed four wheel nuts any sugestions
Put axle stands under the car, do not work using the jack alone!! The alloy wheels fuse/weld themselves onto the hub, try spraying the hub wheel/hub joint with plus gas and hitting the inside of the tyre/wheel with a length of 4" x 2" timber. Put some copper grease on the mating faces when putting them back on again!
i dont want to dis-hearten youbut i know someone who took three days to remove the front wheels on an Alfa Sud!!:evil:
Replied by mahnek on topic Re: Rear Wheels
Posted 13 years 9 months ago #21226
what is plus gas
by mahnek
Posted 13 years 9 months ago #21227
PLUS GAS is a dismantling spray used by the professionals (it is better than WD40) can get it in most car acesssory shops or from Frosts www.frost.co.uk cat no. N220 £5.50 for 200ml ~ they also do their own Free & Easy £4.00 for 500ml. but i prefer Plus Gas. Hope this helps.
Replied by David Aiketgate on topic Re: Rear Wheels
Posted 13 years 9 months ago #21228
If the car is securely raised, i lie on my back on the ground with my feet towards the wheel, legs bent. Then kick/stamp at one side of the wheel/tyre with one foot and then the otherside with the other foot.
Repeat alternating kicks until the wheel comes loose.
Posted 13 years 9 months ago #21229
Thank you will give both a try
by mahnek
Replied by rough luck on topic Re: Rear Wheels
Posted 13 years 9 months ago #21230
Once its secure, plus I normally stick an old wheel under the sill just encase
I'm one for the kick the hell out of it :) rotate it a bit at the same time, boot the tyre not the wheel, takes longer but does no damage
Posted 13 years 9 months ago #21231
It's quite good to relieve stress as well.:rofl:
Replied by Rich in Vancouver on topic Re: Rear Wheels
Posted 13 years 9 months ago #21234
david aiketgate wrote: If the car is securely raised, i lie on my back on the ground with my feet towards the wheel, legs bent. Then kick/stamp at one side of the wheel/tyre with one foot and then the otherside with the other foot.
David, That paints quite a picture!
Any chance of a video tutorial?:woohoo:
Replied by Tigger on topic Re: Rear Wheels
Posted 13 years 9 months ago #21236
Don't fancy the video - when i first read it i thought he was giving birth! :lol:
by Tigger
Posted 13 years 9 months ago #21237
I just knew i'd regret that post.:rofl:
Replied by Titanium on topic Re: Rear Wheels
Posted 13 years 9 months ago #21238
I had the same issue on 3 wheels ! After having tried all the known methods (that are quite dangerous) I developed my own effctive method.
You need a little hydraulic jig (probably the car mech jig should work as well), a wood or steel bar and a belt.
Once removed the 4 nuts :P refit one nut and screw it in 2-3 turns.
Put the jig stem on the nut (to prevent to damage the thread), the bar and the belt (see picture).... pump.
If you are able to remove the central wheel badge it would be better, you will apply the force in the center,
[IMG
As soon as you feel the wheel coming loose stop to pump, otherwise you risk to get jammed the wheel on the hub.
Once removed the wheels, clean the rusted surfaces and apply some FEW copper grease on the mating surface
The following user(s) said Thank You: psymon, David Aiketgate, bryan young
Time to create page: 0.541 seconds
