how to? - polish aluminum?
well thats not a good thing! lol but it means i can enter engine bay build competitions
in this vain i've lots of shiny things for the engine bay including some things that are aluminum but were powder coated
so any ideas on how best to polish said alloy up to mirror like perfection?
ive been told wet and dry? (i have various grades down to 1200)
then autosol?
Replied by David Aiketgate on topic Re: how to? - polish aluminum?
Posted 13 years 9 months ago #21325the trouble is your shiny aluminium bits will continue to oxidise, so you will either have to lacquer it or keep polishing.:yesnod:
- Rich in Vancouver
Replied by Rich in Vancouver on topic Re: how to? - polish aluminum?
Posted 13 years 9 months ago #21327In most cases modern castings are pretty smooth, and once the paint is chemically stripped it just take elbow grease to get a shine. The right felt bobs on a drill or buffer makes the job go much quicker.
Cheers,
Rich
Autosol is your friend!
- rough luck
- Site Sponsor
- Jon
I use about 180 grain wet an dry to get the worst off or paint, then go 300ish
After that it should look like brushed alloy, bit nice an bright
next you can get polishing kits from ebay for about £22ish, these kits connect to an electric drill
You get a spindle that fits both wheels, the wheels are one hard brush wheel and one cotton wheel,
first put the hard brush on, they also come with polishing wax, brown wax is for the hard wheel, load the wheel by spinning the wheel on the wax bar, or by rubbing it on the area your doing
The key to polishing alloy is don't over heat the metal or it will get a ripple effect, once your happy with the surface i.e. no pits or ripples, then change the wheel to the cotton one and repeat it all again with the cotton wheel and the blue wax bar this will bring it up to like a chrome finish
finally a quick going over with autosol and it will look amazing, if its an interior part you only need to polish it up every so often, if its an external part it will need laquer, if when you laquer it sometimes you loose the shine
One way around this is to warm all the area as much as you can with a hair dryer first, then spray a very light coat of laquer and repeat warm then spray until your happy with the effect
Its a real art though so take your time and the speed of doing it comes with time, its a lot like body work but worse to do in some cases as there isn't any paint to cover iffy bits
- bryan young
adam-mgtf wrote: the only good thing about my ZR is it has an engine in the front
then autosol?
Brillo pads work well (fine wire wool & jewelers polish (pink stuff)) use them wet and then finish with Autosol. The details given by Rough Luck is excellent and will produce the results. It takes a long time, take it slowly and it will look superb. Frosts do the Eastwood products and polishing kits. :lol: :whistle:
hmm is there any way to stop heat ripple? the parts im polishing will be attached to the top of the engine
- rough luck
- Site Sponsor
- Jon
You only get heat ripple while your using the polishing wheel if you hold it in one place for too long and thats only really while your using the harder wheel not the buffing cotton wheel, just keep it moving even if its over an area of a few inches an you'll be fine
I only did it they way I did because it seens to be the quickest, ruff paper, then a little finer, the polishing wheel really takes the pit marks out nice an evenly
