Reverse lights not working
The fuse and bulbs are all good and I think the problem may be because I have dislodged the connector to the switch when I installed the Pipercross Viper a couple of weeks ago.
I have read loads of posts but I'm having trouble locating the connector in the engine bay. Any help to locate this would be a big help.
Also is it possible to get to the switch through the top or do I need to go underneath (haven't done that yet )
Thanks.
Replied by David Aiketgate on topic Re: Reverse lights not working
Posted 13 years 9 months ago #21480You can access/replace the switch from beneath.
I had a failed switch last year, where the plunger had worn and was no lomger depressed enough to make a connection.
I'll try to find some pics.
That photo in your post is unfamiliar to me - I haven't got that far in yet :ohmy:
BTW where's the rest of the car! :lol:
Posted 13 years 9 months ago #21482Laz1957 wrote: Can I get to the connector from above, or is going under easier?
I've put a couple of pointers on the pic.
Switch is easiest from below, connector is only gettable from the top.
This is a pic of Clive's car -amid engine removal.
- bryan young
Psymon wrote: Thought that would be Clives, His car in bits are becoming stock photographs
You have one in bits, I have one in bits (no two, including the it must be a MG thing :side: :shrug:
- bryan young
Posted 13 years 8 months ago #21491it's above the oil level, i seem to recall. At least no oil leaked when I changed mine.:shrug:bryan young wrote: David, does oil come pouring out when the switch is removed ?? or is it above the oil level?? ~ Alias had the same problem last year with Flopsy (her F) and if you recall we are still waiting for the video of her groveling underneath the car to fix it. so if a girl can do it, well!!! :whistle: :oops:
I'm half way through putting the scoops onto the side vents at the mo
- bryan young
Laz1957 wrote: I'll let you all know when I get round to it.
Dont want to alarm you, BUT, you could have broken the connection or cut the wires when you were DREMMELING away the resonator box into black granules!!!!!!!! please let us know how you get on, for the small cost i would replace the switch whilst you are there. :silly: :whistle:
I only take it apart so I can take pictures for you lot.
Any suggestions about the cheapest place to get a new switch?
CJJ - you always go the extra mile for us
