Clock & Temperature Control broken
Can the Clock & Temperature Dial be replaced as mine are broken? If so, Any How-Tos, and parts info..
Replied by David Aiketgate on topic Re: Clock & Temperature Control broken
Posted 13 years 8 months ago #21693dg170775 wrote: Last issue for the day..
You mean the clock and oil temp gauges? You can get replacements on ebay. Just be careful to get like for like as the mk1 and mk2F/TF have different faces and connections.
But you'll need to be sure what's not working. Fuses? oil temp sender etc.
Replied by dg170775 on topic Re: Clock & Temperature Control broken
Posted 13 years 8 months ago #21696The Clock just keeps speeding up and shows random times .. even after setting the right time..
The heater dial plastic is broken from the inside.. Infact, while turning it, I can simply pull it out .. and can see the broken edges..
Posted 13 years 8 months ago #21699Even if I buy the part from Ebay .. How do I replace the broken part ?
- bryan young
Replied by bryan young on topic Re: Clock & Temperature Control broken
Posted 13 years 8 months ago #21701dg170775 wrote: I think it's the first Image.. Heater Control Knob.. thats 'broken..
The broken knob should just pull off its fixing and be replaced by the new one. you say the plastic dial behind is also broken, so you may also need the second part, have a look to see what you need before ordering :whistle:
Replied by Laz1957 on topic Re: Clock & Temperature Control broken
Posted 13 years 8 months ago #21710Remove the central heater vent, which is above the central console. This is easily pried out with a flat headed screwdriver, but be careful not to dig into the main dashboard.
Once it's out you will be able to see the back of the clock. You can then pull off the 2 leads (don't loose them) and wait about 5 minutes and then reconnect.
This is basically the old standard power off and on procedure we have all used on PCs at one time or another.
Hope this helps and welcome to the forum
Posted 13 years 8 months ago #21715Please Log in or Create an account to join the conversation.
Posted 13 years 8 months ago #21722There is also a little spring clip inside it that grips theshaft of the heater control unit. Make sure this comes out as well before trying to refit the new one.
