Rear window 2
Rear window 2 was created by wilddog
Posted 13 years 8 months ago #21775
Just fitted a new MkII rear glass window.
Total time 2 hours.
Followed the previous guidance given here and hey presto all fitted, no leaks and used some extra 3 mm rivets.
After chewing off the original sealing foam tape on the lower metal strip and not being able to purchase the like. I found the velcro strips using the fuzzy stuff only, replaced the foam and sealed any gap shown.
new window works a treat.
regards
wilddog cheer:
by wilddog
Replied by David Aiketgate on topic Re: Rear window 2
Posted 13 years 8 months ago #21777
wilddog wrote: Just fitted a new MkII rear glass window.
Total time 2 hours.
regards
wilddog cheer:
Yeah, I used velcro as well. it does the job and won't end up looking like the dog ate it like the foam does.:rofl:
Last Edit:13 years 8 months ago by David Aiketgate
Last edit: 13 years 8 months ago by David Aiketgate.
Replied by wilddog on topic Re: Rear window 2
Posted 13 years 8 months ago #21780
good stuff and will last the weathering as nylon, get in quick as the oil crysis will get worse. £2.00 a litre, ouch, predicted.
My mates reacon the Gulf war was a test, the financial issue a heist followed by the up rising of these people on fields of black gold (oil) for a democracy will only deepen fuel problems.... time to drive my old diesel with cooking fat ! Mmmm Chinese Number 10 with BBQ ribs :silly:
Last Edit:13 years 8 months ago by wilddog
Last edit: 13 years 8 months ago by wilddog.
Posted 13 years 8 months ago #21781
Good job from the photo and well done....... :)
by wilddog
Replied by mgfmania on topic Re: Rear window 2
Posted 13 years 8 months ago #21786
2 hours? did you stop for lunch...lol
Fitting a Glass upgrade panel should take less than an hour; watch me fitting one in 15 minutes:
IF anyone needs 20mm wide, single sided adhesive polyethelene foam strip www.mgfmania.co.uk can supply it for £5 we had to have 1920mtrs manufactured!
Peter
Last Edit:13 years 8 months ago by mgfmania
Time to create page: 0.488 seconds
