2004 TF 135 ~ DRIVERS SIDE WINDOW
- bryan young
the passenger side operates correctly up and down.
Could it be the switch?? or is there a relay that controls the "one touch" operation?? :shrug: :shrug:
Replied by Laz1957 on topic Re: 2004 TF 135 ~ DRIVERS SIDE WINDOW
Posted 13 years 8 months ago #21917Please Log in or Create an account to join the conversation.
Replied by David Aiketgate on topic Re: 2004 TF 135 ~ DRIVERS SIDE WINDOW
Posted 13 years 8 months ago #21923David
- bryan young
Replied by bryan young on topic Re: 2004 TF 135 ~ DRIVERS SIDE WINDOW
Posted 13 years 8 months ago #21929david aiketgate wrote: Assuming the window is moving freely in the runners, I would suspect the switch as well. Could you swap the switches with Kim to see If the switch is the problem?:shrug:
Thank you, window is free in runners, will check/swop switches. is the switch in my 1996 F the same as the ones in her late 2004 TF ?? :shrug:
I believe the window switches are the same throughout the range.:yesnod:
- bryan young
Posted 13 years 8 months ago #22145david aiketgate wrote: Assuming the window is moving freely in the runners, I would suspect the switch as well. Could you swap the switches with Kim to see If the switch is the problem?:shrug:
What would you reccomend to lubricate the window in the side channel, is there a silicone spray that can be used?? I am wondering now if the window is tight in the runners and the safety stop operates because of resistance. the window always comes half way up then stops, another press of the switch and it goes three quarters of the way up then stops again , another push and it closes. press down and it goes all the way. Up again and it stops half way!!!!!!! :shrug: :shrug:
Posted 13 years 8 months ago #22147Spray white lithium; dashshine etc. anything that lubricates really!
- bryan young
Posted 13 years 8 months ago #22148david aiketgate wrote: I use whatever I have available in my magic cupboard.:rofl:
Thank you, i have got some "slatlube" we used to use it on the stainless steel slats on the milk bottle conveyors, it is waterproof and food safe and lubricates very well. :woohoo:
Slatlube,eh? Interesting!:rofl:
