help rear brake guide pin and bolt
Replied by Tigger on topic Re: help rear brake guide pin and bolt
Posted 13 years 8 months ago #22218rayb wrote: help is needed i need a rear caliper guide pin and bolt, its the rear passenger side top bolt and guide pin. i have checked my local scappys and nothing. dont really want to pay for a complete rear caliper when its the bit i need. mine had rusted on and no matter how much lube i put on it . it wouldnt budge . in the end i had to resort to grinding the guide in half just to free the brake caliper to change the brakes. i guess the other side is the same
Damn - there was a rear bolt set on e-bay the other day but i can't find it now. :shrug:
Replied by David Aiketgate on topic Re: help rear brake guide pin and bolt
Posted 13 years 8 months ago #22219Try mgfheaven(vvcsteve) or Mgfntfbitz for these parts.:yesnod:rayb wrote: help is needed i need a rear caliper guide pin and bolt, its the rear passenger side top bolt and guide pin. i have checked my local scappys and nothing. dont really want to pay for a complete rear caliper when its the bit i need. mine had rusted on and no matter how much lube i put on it . it wouldnt budge . in the end i had to resort to grinding the guide in half just to free the brake caliper to change the brakes. i guess the other side is the same
Replied by talkingcars on topic Re: help rear brake guide pin and bolt
Posted 13 years 8 months ago #22221
Posted 13 years 8 months ago #22229rayb wrote: thank you so much thats a nice generous offer, but you live to far for me to pick up thanks again ray
where are u?
- bryan young
Replied by bryan young on topic Re: help rear brake guide pin and bolt
Posted 13 years 8 months ago #22272rayb wrote: help is needed i need a rear caliper guide pin and bolt, its the rear passenger side top bolt and guide pin. i have checked my local scappys and nothing. dont really want to pay for a complete rear caliper when its the bit i need. mine had rusted on and no matter how much lube i put on it . it wouldnt budge . in the end i had to resort to grinding the guide in half just to free the brake caliper to change the brakes. i guess the other side is the same
Must have been bad to have to grind it off, a new guide pin set, boots and bolts (4 units) will set you back around £55. You cant buy just one pin only. but you can buy the bolts in ones" assume the pin was also seized in the carrier. were you using Plusgas to break the rust bond, a lot of people think that WD40 will do the job, but it wont. it is a Water Dispersant and not a penetrating oil. i know it is easy to say now but a bit of heat on the bolt head may have helped. Or ,or, or, you could have used the "rough luck" method >>>> hit it with a big hammer:woohoo: were the calipers seized?? :shrug:
