mgf suspension dropping
rayb wrote: i wonder if you guys have a idea on why my mgf suspension is dropping i had it repumped up last october and now its starting to go down on both sides , there is no hydrolastic fluid leaking, is it the spheres would i need them changing or could it be somethink else that wont break the bank
They do lose height over time, but they are also affected by temperature. How much have they dropped?
Other than checking all the joints and the valves for seepage, it is possible for the nitrogen in the 'other half' of the spheres to leak. Usually gas leaks cause the suspension to become really hard.
rayb wrote: yes david the nitrogen could leak but i would of thought you notice it on one side, but both sides to drop is abit weired i will get it repumped the see what happens. theres diff no leaks you carnt miss the colour of the hydrolastic fluid tho
Agreed, but I have ours pumped up every year, and I've never seen a leak yet.:shrug:
