Which oil
Have heard that Magnatec is the one to go for but wanted second opinions. Also, is there a big difference between A3/B3 and A3/B4 magnatec. Reason for asking is that Ive seen A3/B3 for £3 a litre at B&Q .
As always, thanks in advance for advice.
rog
A3/ B4 Magnatec is the newer stuff that covers both diesel and Petrol engines.
Incidentally I was told that Castrol Magnatec was actually better than Castrol GTX Magnatec, but I can't confirm either way.
Magnatech is lauded on most MG forums.
Anyhoo, you need part synthetic 10w-40.
I used Mobil1 last oil change with no problem
You could try straight GTX as it is cheaper, basically the same oil without the sticky molecules.
Our Mpi seems to sound and perform identically, whether on Magnatec or the Mobil 1.:shrug:cjj wrote: The magnetec seems to make the engine quieter on a VVC, not sure about the non VVCs.
As Clive says, the VVC seems to prefer the Magnatec.
I've seen it in litre containers as well somewhere.:yesnod:rog1963 wrote: Thanks guys. Will probably go for the gtx this year then and see how it goes. Also, am I right in thinking that magnatec only comes (annoyingly) in 4 litres.
- adamelphick
Yep 1 & 4 litre - I always grab a couple when Makro have their £15 specials on just in case!
- Rich in Vancouver
The engine is running very quietly and smoothly.
I hope it stays that way!
Learned something new today ... so you can't really use the filler cap by the dipstick unless you want to spend all day pouring ... I found this out the hard way when I realised that what I was pouring down the funnel was going on the floor....what a dipstick!!
Anyway, at least it was my first opportunity to take the engine bay cover off for the 1st time and see what is actually in there.....and as the weather was nice it beat doing the work around the house for a while.
rog1963 wrote: Finally got around to changing the oil today. Decided in the end to splash out on the magnatec.
It is possible to fill via that one., but you have to remove the dipstick ...and have a lot of patience!:rofl:
And talking of patience, surely all of those bolts on the engine cover aren't necessary :silly:
rog1963 wrote: I did think of removing the dipstick ... but I needed to be there to pour.:lol:
People do leave out many of the bolts... until the thing starts ratting and vibrating.:rofl:
