Has anyone fitted a B&G Coolant Alarm?
Has anyone fitted a B&G Coolant Alarm? was created by rekrab
Posted 13 years 7 months ago #23072
Now that the fine weather is back I decided I would finally get around to fitting the B&G Coolant Alarm kit I got before Christmas.
All has been going well until I got to the step where I have to splice into the 12v Feed. I have a Steptronic gearbox so they give additional advice on where you need to splice into the wiring which is below:
"The live connection (Green with Yellow trace wire) needs to be spliced to a
12 volt ignition feed.
On vehicles up to chassis number 610317 this can be done by connecting to the
white wire going into the relay pack situated behind the engine management ECU
mounting plate."
The instructions are listed here: Coolant Alarm Install PDF
Unfortunately they don't have any pictures. I've had a look and there are a few connectors around there, so I'm not sure which one to choose.
While I'm waiting to hear back from B&G, does anyone know what the Relay Pack behind the ECU plate looks like and can I splice into it as normal? (Either using connectors or just soldering the 2 wires together)
Thanks in advance
Rek
by rekrab
Replied by David Aiketgate on topic Re: Has anyone fitted a B&G Coolant Alarm?
Posted 13 years 7 months ago #23074
I believe any white wire in there is ignition live.:yesnod:
To be honest, I wasn't sure and got my ignition live from the cigarette lighter and fed the wire through to the engine bay.
The following user(s) said Thank You: rekrab
Replied by rekrab on topic Re: Has anyone fitted a B&G Coolant Alarm?
Posted 13 years 7 months ago #23075
Thanks for the post David,
The supplied wire isn't quite long enough to route through to the cigarette lighter, I could always lengthen it I suppose. I might pick a white wire, strip back the covering and put a Multimeter and see what voltage it gets on ignition.
Thanks again
by rekrab
Posted 13 years 7 months ago #23076
rekrab wrote: Thanks for the post David,
Thanks again
looking at the circuit diagram white is ignition live. diagrams
Because my setup is homemade all the delay circuit and warning led is housed in the cabin anyway, so that the only wire I had to take through was the actual float switch feed.
Posted 13 years 7 months ago #23077
Thanks for that. I went and checked the a white wire and it was indeed the 12v Ignition Feed.
So, it's all wired up and beeps/flashes when the ignition is switched on. The only thing that is confusing me is that when I take off the header cap and push down the foam floater the alarm doesn't trip.
(The ignition isn't fully on at this stage, just stage II I think so the power goes through)
I'm a little confused now :)
Thanks for all your help David.
by rekrab
Posted 13 years 7 months ago #23080
My pleasure!:yesnod:
Don't forget that there is a delay built into the system. You may have to hold the float down for a while.
Replied by Rich in Vancouver on topic Re: Has anyone fitted a B&G Coolant Alarm?
Posted 13 years 7 months ago #23082
I put in one of the B&G kits a couple of weeks ago.
Last week I changed the coolant pipes under the car
and gave the system a bleed then topped up the header tank.
On my first drive of about 5 km the warning went off and sure enough the
level had gone down. I topped it up and no problems since, so I guess that this tells me
that both the coolant alarm and the "jiggle valve" automatic bleeders are working as they should.:woohoo:
I hope yours works as well!
Rich
Posted 13 years 7 months ago #23090
david aiketgate wrote: My pleasure!:yesnod:
You were right David :)
20 Second delay and both alarm and LED worked. That makes me feel a lot better :)
Thanks again
by rekrab
Posted 13 years 7 months ago #23091
Rich in Vancouver wrote: I hope yours works as well!
Rich
Cheers Rich :)
by rekrab
Time to create page: 0.949 seconds
