removing/replacing exhaust manifold/downpipe-flexi
- a Guest
- Visitor
removing/replacing exhaust manifold/downpipe-flexi was created by a Guest
Posted 13 years 7 months ago #23250Ok, so remove the engine access cover and this is what you see
remove screw/bolt (was bolt on old car...on this one a screw) for top of heatshield
There is also a bolt at bottom heatshield but no pics as mine didn't have one
Now remove the 3rd heat shield bolt..with spacer...this is 13 mm
5 bolts to remove .....15 mm socket
Now remove the heatshield
Looking from under the car , this is looking up through downpipe to manifold from ground
and a closer shot, looking at manifold/downpipe flange (6 stud manifold)
Now remove bolts form manifold/downpipe flange...15 mm. Use an extension bar to reach bolts. Remove 6 bolts
Now remove cat/downpipe bolts. Mine already had cat saver bolts, so is easy....you may have problems if this is first time!1
Now you need to remove the downpipe from the rubber mount...this is made easier by spraying with WD40 or other lubricant first!
disconnect oxygen sensor plug and then remove the downpipe from car...may take some jiggling.
Attach new gasket to downpipe/manifold flange
also new gasket (and firegum style paste to make a good seal to cat/downpipe flange)
DONT add gum/paste etc to manifold/downpipe gasket as it can damage o2 sensor!!
and ..........reverse!
(attach new or old oxygen sensor BEFORE refitting downpipe)
exhaust manifold bolts = 45 nM....downipe/manifold flange bolts = 50 nM...cat/downpipe bolts ...50 nM
Replied by David Aiketgate on topic Re: removing/replacing exhaust manifold/downpipe-flexi
Posted 13 years 7 months ago #23273David
- Rich in Vancouver
Replied by Rich in Vancouver on topic Re: removing/replacing exhaust manifold/downpipe-flexi
Posted 13 years 6 months ago #23726It's a keeper!
As an alternative to the firegum I have used a product by Permatex
called Copper Hi-Temp Form A Gasket.
I have used it on my TR instead of an exhaust manifold gasket, and it has
stood up well for years.
Looks like those cat nuts are worth their weight in sweat!
- bryan young
Replied by bryan young on topic Re: removing/replacing exhaust manifold/downpipe-flexi
Posted 13 years 6 months ago #23761Rich in Vancouver wrote: That's an impressive how-to.
It's a keeper!
YES, the cat saver "nuts" are worth their weight in gold. and not very expensive either :whistle: :whistle:
Replied by D4KGP on topic removing/replacing exhaust manifold/downpipe-flexi
Posted 2 months 2 weeks ago #208256Please Log in or Create an account to join the conversation.
Replied by David Aiketgate on topic removing/replacing exhaust manifold/downpipe-flexi
Posted 2 months 2 weeks ago #208259Edit. I believe the glitch is created because Broon (the original author) is no longer a member of tbe forum.
Replied by Airportable on topic removing/replacing exhaust manifold/downpipe-flexi
Posted 2 months 2 weeks ago #208260M
