Cold air
- a Guest
- Visitor
I have an 18 yr old Golf as a "back-up" car.....which does of course mean its a daily driver as the MG is always sick.
anyhoos...I notice in this warm weather that the cold air from the blower in the cabin is much colder than that in the F, even though there's an engine bay at the front.
Anyone know why? Does the F take it straight from the "air" at the window intake? Would it be better to take form underneath car, or bumper area? The golf doesnt have AC and I see no path from air to blower that is special in anyway compared to the F.
What is your cold air like....is it 'cold'?
Pete Vickerstaff
MG F/TF Central
- your one stop shop for MGF/TF tips, tricks, faq's, how to's and links
Maybe we should look at a cold air feed for the heater,:lol:
Should be pretty easy to set up.:yesnod:
- a Guest
- Visitor
david aiketgate wrote: Wot he said!:yesnod:
Might look into that. After all, I will need it at least two days every year....so its very important!
Thinking about it, is your heater valve shutting off completely?:shrug:
- a Guest
- Visitor
david aiketgate wrote: I think our cold air in the F is 'proper cold'.
nail....head....perhaps
The temp dial doesn't work properly. It usually either stick on cold to middle, or middle to hot (i.e. I can turn halfway then it sticks, occasionally unsticking). I assumed when it was down at cold, it would be cold, but you are probably 100% correct...and its not closing/opening properly.... makes sense
Might be a dead animal stopping it as there's a horrible smell form the blowers LOL
tomorrows job after the stalling is "fixed"......................
- bryan young
Found that the clip was loose on the cable so re lipped it and adjusted so that I was getting the correct travel. Then I found that it wasn't moving smoothly with the control knob 'skipping' part way through the cables travel. Couldn't see it snagging on anything so Im suspecting a dodgy control knob.
Also now found that on trying the cold position for the first time that with the fan on position 3 and 4 it is blowing 'coldish', but on position 1 and 2 or with it off it is still putting out hot air. Any ideas?
rog1963 wrote: Decided to sort out my cable today, which has been stuck on hot since I got the car.
On the still blowing hot on cold thing, It's just a matter of adjusting the clip on the cable to get cold air at cold and hot at hot.
My knob also does not revolve smoothly, but I think it's to do with valve operation rather than the cable itself.
You need to move the cable up if you want more hot (A) or down if you want cooler (.
- a Guest
- Visitor
