My radiator
  • Visitor
  • Visitor
My radiator was created by a Guest
Posted 13 years 6 months ago #23595
Well, as some might know, when car has been driven for a while, there's a strong smell fo coolant form the radiator area. I was worried in case the radiator was leaking so went to change it today.
removed bumper, slam panel etc ready to get it out, but on inspection it looked perfectly healthy. Even all the clips for the fans etc were shiny new (unlike the one from Maggie which had all rusted). Couldn't see any evidence of leaks and all fins etc were intact.
BUT i noticed some dried coolant around the bleed valve....so in the end I aborted the radiator change and just swapped with the MS valve I took form the other ally rad.................we shall see....no doubt I'll have to do it again...
Oh, and top tip. if you top up coolant, before you go off for a drive..........remember to replace the coolant cap :whistle: :ohmy:
Replied by petevick on topic Re: My radiator
Posted 13 years 6 months ago #23596
could have been a slight weep from the bleed valve. I've had an MS valve for about a year now, still not fitted it :lol: if it ain't broke and all that ;)
Pete Vickerstaff
Replied by David Aiketgate on topic Re: My radiator
Posted 13 years 6 months ago #23601
Have you read this thread ?
A couple of alternatives to the MS kit.
  • Visitor
  • Visitor
Replied by a Guest on topic Re: My radiator
Posted 13 years 6 months ago #23630
As you may have seen in another thread, I went on a longish run today (40 miles) and result.....coolant temp lower than normal (never got above 95) and colant level rose in tank, instead of falling./ I am guessing small leak at bleed screw was enough to prevent proper pressurisation of coolant, so higher temp and loss of "volume" under pressure?
still smell, but probably stuff I spilled when i removed old screw
Posted 13 years 6 months ago #23634
broon wrote: As you may have seen in another thread, I went on a longish run today (40 miles) and result.....coolant temp lower than normal (never got above 95) and colant level rose in tank, instead of falling./ I am guessing small leak at bleed screw was enough to prevent proper pressurisation of coolant, so higher temp and loss of "volume" under pressure?
It's the sweet smell of success Iain!:rofl:
Replied by cjj on topic Re: My radiator
Posted 13 years 6 months ago #23656
Rather than the sweet smell of coolant. :huh:
Time to create page: 0.499 seconds
