Putting the black back
Putting the black back was created by rog1963
Posted 13 years 5 months ago #24666
My hood has started to fade, in particular in the areas where it meets the frame. Is there a suggested product to apply to give it its black back? Also, I'm thinking about resealing it sometime soon, although there are no signs of leaks I'm of the opinion prevention is better than cure. Again, any recommended product. And finally, if there is a product for re-applying the colour, should this be done before or after re sealing?
As usual, thanks in advance.
by rog1963
Replied by David Aiketgate on topic Re: Putting the black back
Posted 13 years 5 months ago #24667
rog1963 wrote: My hood has started to fade, in particular in the areas where it meets the frame. Is there a suggested product to apply to give it its black back? Also, I'm thinking about resealing it sometime soon, although there are no signs of leaks I'm of the opinion prevention is better than cure. Again, any recommended product. And finally, if there is a product for re-applying the colour, should this be done before or after re sealing?
Renovo have a range of hood products that are all good.
Autoglym do cleaner and reproofer as do Turtle wax.
Renovo , i believe are the only ones who do renovator (recolouring).
You need to clean, re-colour and re-waterproof in that order. :thumbsup:
Last Edit:13 years 5 months ago by David Aiketgate
Last edit: 13 years 5 months ago by David Aiketgate.
Replied by rog1963 on topic Re: Putting the black back
Posted 13 years 5 months ago #24668
Thanks David, quick reply as always.
by rog1963
Posted 13 years 5 months ago #24669
Replied by Rich in Vancouver on topic Re: Putting the black back
Posted 13 years 5 months ago #24673
I used the Renovo system on my hood recently and it brought the black back nicely and water beads up on the material.
It will not reoair differences in texture of the fabric caused by abrasion though.
Replied by talkingcars on topic Re: Putting the black back
Posted 13 years 5 months ago #24678
Vacuming makes a difference as it pulls all the dust out.
Replied by bryan young on topic Re: Putting the black back
Posted 13 years 5 months ago #24761
The RENOVO system is far better than the Autoglym one, i have seen hoods done with this and they look like new. a really good clean first is very important, then colour and reproof. System is not cheap, but you get what you pay for. But as Rich has said it will not cover up wear that alters the texture of the mohair. RENOVO is owned by British Motor Heritage is it cheaper to buy direct from them at www.motoringclassics.co.uk :shrug:
Time to create page: 1.498 seconds
