Suspension height challenges
- Tourbillon
FYI the shocks on the back were of different length, so that's the initial problem fixed, maybe the front have the same problem, 2 new units are now on the way. Can you really get 25mm of difference on individual hydragas units?
The good news is the car handles great now, but drives me nuts as i see it sitting wonky on the drive.
Replied by David Aiketgate on topic Re: Suspension height challenges
Posted 13 years 5 months ago #24707Have you tried dropping the pressure slightly on the passenger side?
- Tourbillon
Posted 13 years 5 months ago #24715Tourbillon wrote: That's the next plan, however i wanted to wait until the new shocks arrived to see if the existing passenger front is seized in some way. concern about reducing pressure on one side and not the other is will I get a different spring rate?
You could quickly disconnect the bottom of the shocker to rule that out. I think you could have a 10% difference in gas pressures without any noticeable 'spring rate' problems.:shrug:
Posted 13 years 5 months ago #24716David
Also it could be from the beginning that the distance washer between pin and hydragas unit got lost on one side.
25 mm height is divided by 4 about 6mm pin length (or washer height).
The 425 psi pressure needs be equal on both sides. The LHD car co-driver side needs less pressure.
Adjust the height with the pump. The pressure is less important.
Though, the front to rear difference needs to be equal. (+-5 to 10mm)
Hope this makes sense.
Regards
Dieter
- Tourbillon
Replied by Tourbillon on topic Re: Aw: Re: Suspension height challenges
Posted 13 years 5 months ago #24757many thanks, i plan to change the shocks and then have a play with pressures, i have found a man with a pump and can empty the system and re pressurise. may concern is what David expressed ie. is the pin the wrong one.... guess the answer is to de-pressurise and drop the suspension and re measure.....
Neil
Replied by David Aiketgate on topic Re: Aw: Re: Suspension height challenges
Posted 13 years 5 months ago #24758Tourbillon wrote: Dieter,
Neil
You don't have the old pins then?
- Tourbillon
Posted 13 years 5 months ago #24806Please Log in or Create an account to join the conversation.
